Author Topic: Rear knocking  (Read 6194 times)
Offline Stefanwalker14
Rear knocking
« on: April 22, 2019, 11:19:44 am »
Hi all,
Over the past couple of days I have noticed a knocking noise coming from the rear passenger side of the car, only happens when going over speed bumps, small potholes etc.. anyone have an idea what it could be as it’s rather irritating me!
Re: Rear knocking
« Reply #1 on: April 22, 2019, 11:50:24 am »
Could be a few things... you need to look really. Starting place would be arb bushes
Re: Rear knocking
« Reply #2 on: April 22, 2019, 12:37:29 pm »
Cheers for the reply I shall have a look but might book in with my local vag specialist as I'm not that mechanically minded  :grin:
Re: Rear knocking
« Reply #3 on: April 22, 2019, 02:56:14 pm »
Just had a quick look and the arb bushes look fine to me although perished so might be worth changing? But one thing I did notice was the foam at the top of the shock has started to fall apart so could that be causing the noise or stopping the shock from performing its job?
Offline GTION
Re: Rear knocking
« Reply #4 on: April 22, 2019, 04:42:55 pm »
Had something similar going over bumps and it turned out to be the rubber stoppers at the end of the parcel shelf string as they dangle around the boot and can hit off the side. It was driving me nuts until I figured it out!
Re: Rear knocking
« Reply #5 on: April 23, 2019, 05:28:13 pm »
Found the problem, it’s a loose brake disc back plate of all things :signLOL:
Re: Rear knocking
« Reply #6 on: April 26, 2019, 09:14:36 pm »
Ahh... they are make of tin foil and rust near the screw holes. Glad you found it
  • -Receive: 690
Re: Rear knocking
« Reply #7 on: April 27, 2019, 01:05:15 am »
That's more of a tinny rattling than a knock though!  Knocking normally comes from dead bushes on the swing arms.
Re: Rear knocking
« Reply #8 on: April 27, 2019, 07:49:16 am »
@Pudding yes when outside the car it does sounds like a rattle but it was very loose for some reason!
but when driving seemed to make an odd noise, never easy to describe a noise when there’s so many things to make one  :signLOL:
