Author Topic: Xenons different colour light  (Read 1274 times)
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« on: June 20, 2019, 03:54:22 pm »
Hi, I fitted some xenons a couple of weeks back. One light was white and the other yellowish. The bulb producing the yellowish light went pop so I replaced both bulbs with some cheap ones from eBay.
I've just fitted both new bulbs and still the colour the xenons give out differs between headlights?
Any ideas why this could be?
ta.
Offline Lucky ducky
  • -Given: 30
Re: Xenons different colour light
« Reply #1 on: June 20, 2019, 04:04:47 pm »
When you swapped the bulbs from right to left were you still getting the yellowish light from the same headlight unit?
Offline Lucky ducky
  • -Given: 30
« Reply #2 on: June 20, 2019, 04:06:19 pm »
I got these a while ago colour was perfect
OSRAM XENARC NIGHT BREAKER UNLIMITED D2S HID Xenon discharge bulb, discharge lamp, 66240XNB-HCB, duobox (2 units) https://www.amazon.co.uk/dp/B00FQ8AVHS/ref=cm_sw_r_cp_apa_i_995cDbEV0DC7K
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #3 on: June 20, 2019, 04:31:00 pm »
yes, the offside headlight is the one producing the yellowish light before and after the bulb swap. I usually buy decent bulb but these are my first xenons and I didn't want to spend heavily on bulbs if one of the lights is dying.
« Reply #4 on: June 20, 2019, 06:30:23 pm »
Try swapping the ignitor over see if that is the issue?
