Author Topic: Rattle from engine  (Read 6234 times)
Offline Dave4597
Rattle from engine
« on: July 02, 2019, 12:13:06 am »
Hi, I drive a edition 30 gti notice a rattle from the engine area, sound more like from the chain area and it sounds like a loose chain has anyone ever witnessed something like this before, can it be hydraulic tappets? Thanks!
Rattle can be heard in the attachments
Sent from my H8416 using Tapatalk
Offline muff1991
  • -Receive: 69
Re: Rattle from engine
« Reply #1 on: July 03, 2019, 04:32:44 pm »
sounds like it could be the chain yeah, have you checked your cam follower recently?
Offline Dave4597
« Reply #2 on: July 03, 2019, 04:50:48 pm »
The car got a new cam follower just before I bought it from vw, sounds like it's coming from the timing chain area, is it common for the tensioners to go?
Offline muff1991
  • -Receive: 69
« Reply #3 on: July 04, 2019, 11:42:45 am »
yes, quite common for the tensioner to fail or start "failing" and also chain stretch. defo worth having it looked at mate.
Offline Dave4597
« Reply #4 on: July 06, 2019, 11:19:25 pm »
Thanks buddy gonna book it in for a new chain and tensioner
Offline Dave4597
« Reply #5 on: July 13, 2019, 12:38:29 pm »
Car went to vw, they inspected the issue and got a new hydralic tappet the noise was away for couple of days but it came back need to book it in again pretty sure it sounds like a chain tensioner as the tappet didn't fix it
Offline muff1991
  • -Receive: 69
« Reply #6 on: July 13, 2019, 12:45:02 pm »
What’s your mileage dave?
Offline Dave4597
« Reply #7 on: July 13, 2019, 12:55:20 pm »
The car currently has 107k
Offline muff1991
  • -Receive: 69
« Reply #8 on: July 13, 2019, 01:20:46 pm »
It sure could be the chain and tensioner then. Do you have a ticking/rattling on idle when the engines at operating temperature and hardly no noise when cold?
Offline Dave4597
« Reply #9 on: July 13, 2019, 01:41:05 pm »
Noise when first started and on operating temperature
Offline muff1991
  • -Receive: 69
« Reply #10 on: July 13, 2019, 01:48:38 pm »
Probably is the chain and tensioner mate. Look at getting it replaced.
If you’re good with the tools it is something you can do yourself you can buy it all as a kit.
Offline Dave4597
« Reply #11 on: July 13, 2019, 07:24:36 pm »
Gonna book it it again and if they not fix it I'll just do it myself because its annoying driving such a nice car and hearing that noise. Thank you for your help so far!!
Offline muff1991
  • -Receive: 69
« Reply #12 on: July 13, 2019, 09:58:47 pm »
No worries mate, that’s what the forum is for right :-) hope you get it sorted ok.
Offline Dave4597
« Reply #13 on: August 09, 2019, 03:54:28 pm »
After long two weeks finally got the car back. Vw have replaced the camshaft  adjuster, timing chain, tensioner and the cam follower the car sounds so much different now. The only thing you hear is the injectors which is normal in these engines but it's running nice and smooth. Thank you  for the help and I hope this will help someone who will have the same issue.
Online fakie1977
« Reply #14 on: August 10, 2019, 06:02:53 am »
If you don’t mind posting could you indicate how much VW charged for this?  Assume it was parts and labour. Thanks
