Author Topic: Car fault- help needed  (Read 1193 times)
Offline jim85
« on: August 21, 2019, 08:25:24 pm »
Ok having a bit of an issue with my car, it’s a mk5 gt tdi 140, got it mapped a few months ago, was driving it on Saturday and while cruising at 50mp I noticed it started accelerating upto 60 with out pressing the accelerator any more, then when I got in the lower gears sitting at 20-30 mph when it hit around 2000rpm it would start bucking and juddering and the revs would shoot upto 3000, no lights on the dash have flashed upit’s currently in the garage and the mechanic is struggling to pinpoint the exact issue and has warned me I could be throwing money into it to get it fixed, thinking it’s a fuel injector issue, so not sure if I should try change the wiring loom at first as it’s the cheaper option and see where it takes me, just wondered if any line had a similar issue and could help shed some light.  :rolleye:
Offline titchy
Re: Car fault- help needed
« Reply #1 on: August 22, 2019, 09:07:49 am »
Get someone with VCDS don't just throw money at it get it diagnosed properly
Offline jim85
« Reply #2 on: August 22, 2019, 04:53:51 pm »
Thanks mate, that’s what I’m worried about, that garage I took it to I think had a obd reader, got it booked into a be specialist garage now so hopefully they can diagnose properly, would the map affect them using VCDS?
Offline muff1991
  • -Receive: 69
« Reply #3 on: August 22, 2019, 05:47:30 pm »
Defo get it plugged into VCDS, you’re on the right track by taking it to a specialist. No, the map won’t affect anything at all.
Offline jim85
« Reply #4 on: August 23, 2019, 05:20:28 pm »
Thanks for the reply, got to wait till Thursday to take it in, I’m hoping it’s the injector wiring loom, anyone had one of those fail before? What’s the symptoms?
Offline amanda
« Reply #5 on: August 23, 2019, 06:35:56 pm »
Fuel injectors in my book are service items sadly as they are a common failure
