Author Topic: Fault code  (Read 1053 times)
Offline Tally
Fault code
« on: September 28, 2019, 02:55:45 pm »
Anyone ever had issue with.
Fault code P0275 intake temperature sensor G4 signal too high. P0113 lower limit reached. Intermittent
Offline muff1991
  • -Receive: 69
Re: Fault code
« Reply #1 on: September 30, 2019, 03:04:21 pm »
doesn't ring any bells to me, but first i'd check the wiring.. one will be the earth and the other should give you around 5v. if all ok then replace the sensor.
