All Things Mk5 > Performance Modifications
Aftermarket Oil cooler
<< < (3/3)
bobby_fodge:
--- Quote from: Pudding on January 17, 2020, 04:13:49 pm ---I can't remember which measuring block it is.  If you pull up the advanced measuring blocks list, it should be in there somewhere.
Do you get any clattering noises from the engine?  Hydraulic lifters and chain tensioners aren't fond of low oil pressure.
--- End quote ---
Engine sounds like it always has, far from refined but nothing unusual.
LC5F:
--- Quote from: bobby_fodge on January 17, 2020, 04:08:25 pm ---The pick up, oil pump and oil pressure sensor were replaced at Xmas.
--- End quote ---
Did the oil pressure problem start before or after that lot got changed?
bobby_fodge:
--- Quote from: LC5F on January 17, 2020, 06:45:46 pm ---
--- End quote ---
--- End quote ---
Before.
shannon-ob:
Yes, I have fitted a Mocal oil cooler with a remote stat. Using the HEL take off plate.
Octoparrot:
If you fit an oil cooler then you're really only fighting the symptoms and not the disease.
Navigation
[0] Message Index
[*] Previous page
Go to full version
