Author Topic: GTI Track Car - Now big turbo, sidewinder.  (Read 50671 times)
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
Do you use any chemicals or just wire wheel on a grinder to get all the underseal off?
Just a wire wheel on the grinder. Wish there was some kind of chemical I could have left on there to soak. It was hard work.
Thanks. I was hoping you'd found some miracle stuff that made the job less of a nightmare. I've had the stonechip and that for two years and still haven't done it.
Offline shannon-ob
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=uqa1kjs1ne2du8iifdomhcs9pu&/topic,124095.0.html
It's not a job I'd want to do again, not even if i was being paid  :jumping:
MY 3 DOOR 370BHP MANUAL GTI TRACK BUILD - WAVETRACK DIFF, CAGED, POLYCARBS, KO4, DB9 BRAKES, METH, BARTEK, VIS, HELIX PADDLE CLUTCH/SMF, FLOCKED DASH, 18X9 PRO RACE
https://www.mk5golfgti.co.uk/forum/index.php/topic,124095.0.html
Instagrams;
@shannon_ob
@dinger_developments
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=uqa1kjs1ne2du8iifdomhcs9pu&/topic,19740.0.html
I believe these are 1166 if i remember corectly I’ll have to look back into it.
Do those match yours except for the compound difference?
Offline shannon-ob
I believe so mate yes. I’d have to pull one out.
Instagrams;
@shannon_ob
Offline shannon-ob
I’ve had many comments regarding the arch kit from friends and social media expressing how the car was in desperate need of some side skirts.
Well, I’m currently breaking a MK1 Leon Cupra R and had a brain wave regarding the side skirts. I offered them up to the golf and found they were only 5mm or so too short of fitting. With the rear arches I didn’t need the end anyway, so I cut the end cap off. I then stupidly decided to cut where the skirt met the rear arch, as I thought it would be easier to scallop the end piece to fit the arch. BAD IDEA. Then meant plastic welding it back together, which was harder than I thought. Never done it before. Got the hang of it in the end though.
I have made a little more progress than these pictures but forgot to get updated ones. I am actually smoothing the jacking covers into the skirts.
I still need to do a little more fettling with the end piece that meets the rear arch. But otherwise, I’m happy with the result.
Instagrams;
@shannon_ob
Offline shannon-ob
Progress has been made!
I sent the engine over to a friend to have the inlet valve blasted. I do have more pictures, but you get the idea.
Finally got the bay painted!
First coat laid down.
The finished product, Porsche Crayon Grey with red flake in the lacquer. The flake will only be in the engine bay. Not over the whole car. (Very hard to see the flake in pictures, sort of need to take a picture out of focus.)
 Got the KO4 injectors tested by TSR Performance. Came back all good.
Finally got the engine back in the hole last night.
That’s it for now.
The finish is in sight!
Instagrams;
@shannon_ob
Offline Hypertuned
Nice! Can see the flake in the pictures but it kinda looks like the paints dirty. Lol But I'm sure it will look better in the light
Sent from my SM-N9750 using Tapatalk
Offline shannon-ob
Haha, yeah. Alarmist looks like I’ve been grinding near it.
Does look amazing in person. I’ll try get pics outside when the sun is out!
Instagrams;
@shannon_ob
Offline shannon-ob
Sorry it's been a while, again...
Let's try and do this in some order  :signLOL:
I bought a very cheap set of Nankang AR1 245/40/18 from Chris McDermott, he'd only done a few laps on an evening session!
Next, I'd bought a new Ramair ProRam filter - Sadly myself and Eddie (who does my fab work) had a little communication error and the filter is on the big side. However, you'll see a little further on that it doesn't loom to bad in the end.
Bought some bits for the pipework that Eddie has done:
K03 to K04 DV loom
Some silicone bends etc.
MAP boss
Small K&N for custom catch can (not yet fabricated)
Here's the finished work by Eddie! Yes, titanium intake  :love:
Can also see here my Spal fans, aluminium rad and custom fan shroud.
Some pictures of the Golf on the ramp
After bleeding the clutch and brakes - I drove the car out the unit under it's own power!
Bought some things...
Spray booth for the unit  :stupid:
Also bought some cheap cars...
An A3 2.0tdi Quattro (snapped cambelt) I've broken it for parts and going to keep the Quattro set up for the golf for future  :evilgrin:
Bought a MK5 GTI DSG with a good spec, needing an engine which I also bought, fit engine, sell for profit.
Also bought a standard Polo GTI 9N3 that I was going to put a new gearbox in and sell on, but ended up giving to younger brother as a track toy  :ashamed:
Anyway, back to the Golf - Mapping is booked at TSR for 13th October  :grin: before that, I'm hoping to get an alignment and MOT on it! Hopefully, my new Recaro SPG's will be here in time!
Thanks for reading  :happy2:
« Last Edit: September 19, 2021, 01:19:49 pm by shannon-ob »
Instagrams;
@shannon_ob
Offline Clarkj93
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=uqa1kjs1ne2du8iifdomhcs9pu&/topic,131272.0.html
Good to see it starting to be put back together! When you hoping to get it on track again? Next spring? Wouldn't mind seeing this go!
Offline shannon-ob
God damn you! You replied to quick ahaha, it's now in order with some wording.
I'm hoping I can get out at Combe on the Halloween Action Day for a little tester before splashing out on track days!
Instagrams;
@shannon_ob
Offline Clarkj93
Haha thought you cba to explain them!
Nice! Just give yourself space from all the weapons that turn up to those action days track sessions sometimes :doh:
Offline shannon-ob
Yes, I know all about them... Last session I went out on I had a Zafira GSI trying it's hardest to keep up with with me - it was very quick in the straights. But cheap brakes meant he'd kept setting fire to his pads!! So I just let him past. GOONS!!!
Instagrams;
@shannon_ob
Offline shannon-ob
Car went off for a quick alignment at Harvey’s Autotech
Eddie came down and welded up my catch can. It’s come out perfectly!
I’ve also changed the spark plugs to NGK BKR8EIX as per recommendation from TSR, who will be mapping the car.
They also said to put 10W/60 oil in it so that’s what I’ve done. Fuchs Titan is what was used.
Mapping is Wednesday 13th - well that’s when I’ve got to drop the car off to probably collect Saturday.
That’s it for a minute.
Instagrams;
@shannon_ob
Offline LC5F
  • -Receive: 80
That intake is a work of art - very neat welds
