Author Topic: New pirelli edition owner  (Read 2880 times)
Offline STU175
« on: February 10, 2020, 05:10:18 pm »
Hi everyone im Stu
Just bought a silver pirelli edition dsg 3 door with 76k on the clock. has a miltek cat back, airfilter, stage 1 map and i think its  eibach suspension.
Does anyone recognise it?
well happy with it ive had quite a few golfs in the past list includes....lol
mk1 1.1
mk2 1.3
mk2 8v
mk2 16v
mk4 20v
and finally a corrado g60 that i still have.
not sure if the picture is gonna work
https://1drv.ms/u/s!AqPZCuIzj1FMgooQZ_SnS0dAqRCLwA
Golf Gti Pirelli Edition 3dr Silver DSG 76k - Miltek cat back, Eibach Suspension, K&N Panel filter, Stage 1 map, so far....
Offline terrier
  • My Ride: GTI now gone
Re: New pirelli edition owner
« Reply #1 on: February 11, 2020, 06:30:24 am »
Pic works :happy2:  but why no G60 pic :drool:
Offline shannon-ob
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php/topic,124095.0.html
« Reply #2 on: February 11, 2020, 09:23:20 am »
Welcome Stu!
Nice looking Pirelli you have :)
MY 3 DOOR 370BHP MANUAL GTI TRACK BUILD - WAVETRACK DIFF, CAGED, POLYCARBS, KO4, DB9 BRAKES, METH, BARTEK, VIS, HELIX PADDLE CLUTCH/SMF, FLOCKED DASH, 18X9 PRO RACE
Instagrams;
@shannon_ob
@dinger_developments
Offline Powervalve Nige
  • Trader - 2014
  • -Given: 84
  • -Receive: 76
    • POWERVALVE
« Reply #3 on: February 11, 2020, 11:05:49 am »
Very nice - right number of doors as well ;-)
Nige
Offline STU175
« Reply #4 on: February 11, 2020, 06:16:07 pm »
ha ha here you go then.
ive played with it a little over the 17 years ive owned it!...
spec list below
1991 VW Corrado G60 Supercharged 1870cc. 4 Cylinder. 8v. 252bhp
ENGINE:-
JMR Stage 4 Charger & 68mm Pulley Rallye U bend & Wagner Intercooler.
JMR Big Valve Ported “P Type Head” Schrick 268/276 Camshaft.
83mm Wossner Forged Pistons & Conrods. Ported Inlet Manifold.
G-Werks 4-2-1 Exhaust Manifold & Custom Stainless-Steel Exhaust System.
Lightened Flywheel & Fully Balanced Bottom End.
Dubforce Custom Map
315cc Red Top Injectors.
Sytec Adjustable Fuel Pressure Regulator & gauge Max RPM Alloy Pulleys.
330mm Mocal Oil Cooler with thermostat. Carbon canister removed.
Samco Boost & Coolant hoses Bar-Tek Boost pipe.
K&N Panel in Standard Air-Box & Custom air feed.
Solid Front Engine Mount. Schrick Sump & Windage tray.
Golf G60 525mm Radiator Slimline Fan Evans Waterless Coolant
TRANSMISSION :-
Passat TDI Gearbox. Redline MT90 Oil.VR6 Clutch. Hel braided clutch hose.
SUSPENSION:-
AP Racing coil-overs, New powerflex bushes all round, Refurbished front sub-frame, ARB & rear axle. Eibach Camber bolts.
BRAKES:-
Audi S2 Front Twin Pot Calipers, 9” 229mm Servo.T4 25.4mm Master Cylinder.
Braided hoses & New cupro-nickel brake lines. Rear Disks skimmed 6mm.
BODYWORK:-
Full Glass out re-spray in original L90e Alpine White, Engine Bay smoothed and Wire Tuck.
Re-undersealed & Painted, Late Style VR6 Bonnet slam panel and wings.
Smoothed VW badge & Seams. Colour coded handles, wing mirrors & number plate plinth.
Clear side indicators. Tinted front lights and indicators.
Lupo aero wipers. Mk5 Golf washer filler neck & universal washer bottle.
INTERIOR:-
Upgraded to late style black cloth Interior including stalks & vents.
WHEELS & TYRES:-
9x16 Borbet A wrapped with 215/40/16 Event tyres. 7x16 Borbet A wrapped with 195/45/16 Yokohama S-Drives.
I.C.E:-
CD/USB/TUNER 600w Kenwood Amp. Kenwood Components up Front. 10in Sub in boot.
Remote full closure alarm/Immobiliser/central locking upgrade to MK4 Golf Keyfob.
https://1drv.ms/u/s!AqPZCuIzj1FMgaY76Te_z1TK7WJoUg
https://1drv.ms/u/s!AqPZCuIzj1FMgaVyYPW-RgneBWB6PQ
https://1drv.ms/u/s!AqPZCuIzj1FMgaY6X2GaGS82dG7W_Q
Offline LC5F
  • -Receive: 80
« Reply #5 on: February 11, 2020, 11:28:17 pm »
 Agreed - correct door count - good looking Pirelli
Rado pics please!
Offline STU175
« Reply #6 on: February 12, 2020, 10:32:19 pm »
has to be a 3 door  :happy2:
all my golfs apart from the mk4 were 3 door too, look so much nicer.
my 160k mk4 gti spat out a piston ring so i started looking for a cheap mk5 gti to replace it.
well that didnt happen!
stumbled across a black pirelli edition for sale and after a bit of research decided this was the mk5 i wanted.
i wasnt to sure if i wanted a manual or dsg so i went to look at a lower mileage silver one id found for sale.
went for a test drive and was sold on the DSG and the car!
original budget forgotten about i borrowed the rest to get it. only live once hey
plans are to get all the service stuff out the way then bigger brakes.
i need to research what options there are that fit under the pirelli alloys or any suggestions?
heres a few more pics from the ad
https://1drv.ms/u/s!AqPZCuIzj1FMgooN5TMcuJQZVxON1w
https://1drv.ms/u/s!AqPZCuIzj1FMgooUBbH2VHqSM2iGoQ
« Last Edit: February 12, 2020, 10:34:30 pm by STU175 »
