Author Topic: RNS 510 display colour schemes  (Read 18995 times)
Offline xxx_mojo_xxx
  • MUBster DUBster
Re: RNS 510 display colour schemes
« Reply #15 on: March 09, 2010, 08:07:17 pm »
What version of display is set to RNS for the factory fit units in a Mk 5?
Highline, I think. It's the one yours is set to in the first post.
My GTi came with the sport line theme from factory.
« Reply #16 on: March 09, 2010, 08:54:52 pm »
That's because they saw you in yer trackies mate!  :P :P :P
 :grin: :grin: :grin:
Offline Rob GTI
« Reply #17 on: May 26, 2010, 09:47:45 pm »
Can only be done via vcds.  but if you have access to vcds then its in controller 37 navigation byte7 bit 4-5 the selection is either premium, highline or sportline the highline is what you have on now the premium is the reverse to that and the one you want is sportline the red/black.
Darren
I eventually got myself VCDS and tried to change the display setting via the long  coding, I can see the option to change between trhe 3 options and it says coding has been accepted, however the display is still the same.
I ran a scan and there are some faults logged under nav /radio:
VCDS Version: Release 908.2
Data version: 20100326
Wednesday,26,May,2010,21:45:03:08280
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 77
VIN: WVWZZZ1KZ7W283357   Mileage: 55320km/34374miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 L    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0030
   Revision: 5BH16---    Serial number: VWZ7Z0G8150775
   Coding: 0403000318070160
   Shop #: WSC 78905 027 444167
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0004738
   Shop #: WSC 01279 785 00200
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1K0 907 044 BN    HW: 1K0 907 044 BN
   Component: ClimatronicPQ35 110 1010
   Revision: 00110021    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000007056844
   Coding: E78F8F2700041500471400001400000000087F075C0001
   Shop #: WSC 00000 785 00200
   Part No: 1K2 955 119 E
   Component: Wischer 040507 021  0501
   Coding: 00038805
   Shop #: WSC 00000
   Part No: 1K0 955 559 AB
   Component: RLS     100507 020  0105
   Coding: 00208933
   Shop #: WSC 00000
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: 38 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD17GBUS
   Coding: 0013112
   Shop #: WSC 01269 785 00200
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenksäulenmodul 036 0070
   Coding: 0000042
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K6 920 973     HW: 1K6 920 973
   Component: KOMBIINSTRUMENT VDD 1610
   Revision: V0003000    Serial number: VWZ7Z0G8150775
   Coding: 0007403
   Shop #: WSC 00488 210 71781
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 080507F1000576
   Coding: 7D0F03C807000001
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.lbl
   Component: IMMO            VDD 1610
Address 37: Navigation (J0506)       Labels: 1T0-035-680.lbl
   Part No SW: 1T0 035 680 C    HW: 1T0 035 680 A
   Component: RNS-MID       H04 2660
   Revision: AB001001    Serial number: VWZ6Z7H6010110
   Coding: 000004000400001200
   Shop #: WSC 05314 000 00000
   ASAM Dataset: ------------------------- ------
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 46
                    Mileage: 48436 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:53:09
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1K0 959 701 M    HW: 1K0 959 701 M
   Component: Tuer-SG         005 0984
   Coding: 0000564
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
            005 - No or Incorrect Basic Setting / Adaptation
Address 44: Steering Assist        Labels: 1Kx-909-14x.lbl
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.074 H07 1806
   Shop #: WSC 00000 028 00001
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0204
   Revision: 00020000    Serial number: 00000000000000
   Coding: 919002085103087F2D040F0F70085AC690BC00
   Shop #: WSC 00705 210 60120
   Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Part No: 1K0 951 178 A
   Component: Neigungssensor  003 0203
   Component: Innenraumueberw.003 0203
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1K0 959 702 M    HW: 1K0 959 702 M
   Coding: 0000564
Address 55: Xenon Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0003
   Coding: 0000003
Address 56: Radio (J0506)       Labels: 1T0-035-680.lbl
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 46
                    Mileage: 48436 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:53:09
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 1Z0 035 729 B    HW: 1Z0 035 729 B
   Component: FSE_2P7x        H31 0050
   Revision: 00000001    Serial number: 00000005006502
   Coding: 0000402
End   ---------------------------------------------------------------------
Any ideas anyone?
GTI Edition 30 No. 907, 3 door, Black. (Now Sold)
Offline Neimad
« Reply #18 on: May 26, 2010, 09:56:28 pm »
Any ideas anyone?
The error in your Radio / Navigation system sounds simple enough -- the GPS antenna isn't connected correctly or is damaged.
The error with your door controller I'm not so sure about -- sounds like there's a problem with the coding though.  Have you recoded the door controller or swapped it for another one at any point?
Finally, to get the nav to change theme you have to restart it by pressing these buttons:
Offline Rob GTI
« Reply #19 on: May 26, 2010, 10:24:22 pm »
Thanks for that, I figured it out about 5 mins after posting!!
Not sure I like the other schemes now I've seen them in real life.
Perphaps the error with the nav antenna is because its after market?? Or maybe not connected properly I only ever seem to  get about 4 satellites out of 8 or 9.
Offline Neimad
« Reply #20 on: May 27, 2010, 09:09:20 am »
I have an aftermarket antenna on mine and get about the same amount of satellites so I don't think that should be the problem.  Might just be worth pulling the dash apart (it's a pain I know!) and making sure that the antenna is connected securely.
Offline Rob GTI
« Reply #21 on: May 27, 2010, 06:48:11 pm »
Just had a thought about the antenna thing. I remember while i fitted the BT I had the RNS switched on without the antenna in, perphaps this is what logged the fault code. MAybe if I clear the fault it will not repeat.
cameluk
« Reply #22 on: May 27, 2010, 07:15:24 pm »
Was that approx 6884 KM after the scan you posted above ?
Offline Rob GTI
« Reply #23 on: May 28, 2010, 07:12:35 pm »
I see where yourt going with this!!
Yes it does tie in, lets get re-setting and see if thats the end of that  :happy2:
« Reply #24 on: May 28, 2010, 08:18:23 pm »
Your door electrics should be sorted if you do this: window all the way down. Then window all the way up but keep your finger on the up button for five seconds after the window reaches the top
