Author Topic: Milltek vs Pipewerx  (Read 10513 times)
Offline Cozza
Re: Milltek vs Pipewerx
« Reply #15 on: July 11, 2020, 08:02:22 am »
Top tip
Always ask what cat washcoat weight is  :wink:
A 5-gram washcoat will get through an MOT, but due to it being an entropic surface coating it degrades with use - so you have to wonder how many times.
The main cost element is in the precious metal coating, the greater the load the higher the cost.
If you can't get an answer or they don't know walk away.
FYI the OEM cat will typically have a 60gram coating.
Cheers'
Nige
Thanks for that info. Admittedly none of that was asked before purchasing but now I know for future reference. May have to upgrade to that powervalve sooner then anticipated!
Offline Cozza
« Reply #16 on: July 11, 2020, 08:10:03 am »
Mine passed MOT no problem at all back in March. Bought brand new & had been Fitted just over 7 months prior.
So did my APR DP with the sports cat, only just, the first year.  Second year, flat out fail.
Interesting.. I wasn’t aware some high-end sports cats had such a short lifespan, don’t get me wrong I knew that they didn’t last forever but a year seems mental.. especially for the price people pay for them too.
« Last Edit: July 11, 2020, 08:15:34 am by Cozza »
  • -Receive: 690
« Reply #17 on: July 11, 2020, 11:56:54 am »
Tell me about it.  The APR DP with 'GESI' cat (iirc) cost me £750 3 or 4 years ago!
I get my MOT done at the local dealer so there's no rule bending with those guys.  I actually want them to find stuff to fix as it gives me something to do  :grin:
Anyway, first year with the APR it passed but the VW tech said he had to drive it hard for 10 mins to get the cat hot enough to pass.  It failed on the first attempt.
Second year it just flat out wouldn't pass.  CO spec is 0.01%. Can't remember the outer limit for a pass but the APR cat when roasting hot only managed 0.1%. 10 times worse than OEM!
Offline Powervalve Nige
  • Trader - 2014
  • -Given: 84
  • -Receive: 76
    • POWERVALVE
« Reply #18 on: July 13, 2020, 02:21:35 pm »
The BCS Powervalve washcoat provides 0.00% on the Co both fast idle and natural idle and 4ppm (parts per million) on the Hydrocarbons (pass is less than 200 ppm - OEM reading is 1 ppm)
Get the data before you pay ;-)
Nige
  • -Receive: 690
« Reply #19 on: July 17, 2020, 06:22:34 pm »
Impressive  :happy2:
Are all your systems 3" or is there a 2.5" option?
  • Trader - 2014
  • -Given: 84
  • -Receive: 76
    • POWERVALVE
« Reply #20 on: July 20, 2020, 09:54:06 am »
All of our systems are 3.00"  and come with a huge variable option list :happy2:
Nige
Offline Mobrrown45
« Reply #21 on: July 22, 2020, 04:15:14 pm »
Just got a full milltek system, will it be MOT friendly?, haven’t fitted it yet so may stay with stock if so
Offline Wastedspark
« Reply #22 on: May 10, 2024, 07:19:32 am »
Hi
Is there much of a difference in noise when fitting an after market down pipe? I currently have a miltek cat back with resonator on my mk5 GTI
Offline ZoliWorks
  • -Receive: 20
« Reply #23 on: May 10, 2024, 09:13:24 am »
I've fitted a 200 cell downpipe. Only difference I noticed is a rattling sound under acceleration. There's no difference in noise. I've kept the original exhausts and I probably wont replace them because I want the car to be comfy on long roads. It has the exact same sound as my naturally aspirated golf, which has a sports cat because it was the cheapest option as a replacement part when my OEM cat failed. Sound video below.
Like it's not rattling in the proper sense, but I have no clue how to describe it. Basically a sound that wasn't there with the stock cat.
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend Clutch Kit | Ta-Technix Air Intake | Ta-Technix Cat-less Downpipe | Ta-Technix Sandwich Intercooler | OEM S3 Injectors | Vis Motorsport 175 bar HPFP | 350hp 480nm
Offline Wastedspark
« Reply #24 on: May 10, 2024, 09:15:30 am »
Is it the tingy noise you get from a stainless exhaust? Hopefully not detonation!!!
Offline ZoliWorks
  • -Receive: 20
« Reply #25 on: May 10, 2024, 10:04:52 pm »
Yeah that's the one. Tho it's funny. The rest of the exhaust on the Jetta is stock while the downpipe is custom all the way back to under the rear seats where it's connected to the exhaust. On the golf the whole system is stock, minus the cat, which is a sports cat.
