March 14, 2025, 06:41:08 pm
All Things Mk5
Mk5 General Area
Alarm 07 plate eddy
Topic: Alarm 07 plate eddy (Read 1271 times)
Geoffjackson
Can't Read PM's Yet!
-Given: 0
-Receive: 0
Alarm 07 plate eddy
July 01, 2020, 06:40:06 pm »
Hi folks
Had the car a good few weeks and alarm has just randomly started going off. This is worrying as it will soon start annoying the neighbours.
I have clicked the button twice and pressed the switch de-activation internally near the seatbelt as a temp measure. Should this give me a quiet night or would I be better just licking with key.
Would the alarm go off with a dying main or siren battery even if it isn’t armed??
Cheers In advance
pudding
Global Moderator
Just look at my post count
-Given: 2
-Receive: 690
Re: Alarm 07 plate eddy
Reply #1 on:
July 04, 2020, 04:38:42 pm »
I would hazard a guess the alarm controller thinks a door or window is open, or there might be a fly trapped inside the car buzzing around triggering the cabin sensors.
Have you scanned the car with VCDS to check for fault codes?
carsten
-Given: 0
-Receive: 2
Reply #2 on:
July 04, 2020, 07:35:00 pm »
I had the same issue, it was the alarm horn internal battery that had given up. New from Aliexpress and all quiet again.
Geoffjackson
-Given: 0
-Receive: 0
Reply #3 on:
July 06, 2020, 07:39:04 pm »
I have the car booked in to plug it in to vcds to see if I can find the culprit
Will keep updated on my progress
All Things Mk5
Mk5 General Area
Alarm 07 plate eddy
