Author Topic: 996TT caliper squeal!  (Read 1509 times)
Offline shannon-ob
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php/topic,124095.0.html
« on: July 07, 2020, 11:16:57 am »
Hello all,
I'm having an issue with my MK5 that has 996TT calipers fitted.
The issue is, terrible brake squeal. Like ear piercing high pitched squeal!
I bought the kit second hand, with refurbished calipers.
The kit came with:
The calipers (freshly powder coated with new seals etc)
350x32mm MTEC J hook discs (little wear/use)
Centring rings (new)
HEL braided lines (new)
Motul RBF600 (new)
Vagbremtechnic adaptors for alloy hubs (used)
Pagid Road pads (used, lots of life left)
Ferodo DS2500 pads (like new)
I started off with the DS2500 and they were fine for some number of miles then gradually they started squealing, then got to the point the car was un-driveable. So then I switched to the Pagid pads. Again, to start with they were fine but then the same noise.
Just wondered if anyone else has experienced similar issues?
Someone I have explained to has said to try a 2 piece disc set up.
Many thanks.
MY 3 DOOR 370BHP MANUAL GTI TRACK BUILD - WAVETRACK DIFF, CAGED, POLYCARBS, KO4, DB9 BRAKES, METH, BARTEK, VIS, HELIX PADDLE CLUTCH/SMF, FLOCKED DASH, 18X9 PRO RACE
Instagrams;
@shannon_ob
@dinger_developments
Offline terrier
  • My Ride: GTI now gone
Re: 996TT caliper squeal!
« Reply #1 on: July 07, 2020, 02:11:58 pm »
Have you tried shims with ceratec  :happy2:
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
Offline MichaelRew
  • Newbie
    • nevermind
« Reply #3 on: November 06, 2020, 07:35:37 am »
I am doing some work on my sons Anni which is fitted with an Abbot big brake kit. I am having trouble sealing the lines at the calipers. The issue is getting a seal across the banjo bolt to the caliper. There is a washer either side of the bolt. Should they be copper or Bellville? The current ones seem to be copper but perhaps need annealing. Anyone know the part nos?
variant5
