Author Topic: Forge Recirculating Diverter Valve vs VW Diverter Valve (Rev. D)  (Read 18611 times)
Offline xxx_mojo_xxx
  • MUBster DUBster
Which one is better?
Responses to be accompanied with supporting arguments, e.g. VW regulates boost pressure a lot quicker, or Forge one can handle higher boost pressures.
Offline snapey
Re: Forge Recirculating Diverter Valve vs VW Diverter Valve (Rev. D)
« Reply #1 on: March 12, 2010, 10:11:20 am »
I've got the revision D next to me. Had the forge and it seemed like a pain in the arse to fit and plumb in. Besides I'll be selling up in about 6/7  months I wanted to keep it OEM so save the hassle of taking the forge and associated pipework off when I sell it.
Thats the only reason why I swapped and went for the OEM version. I'd have no doubts about the ability of each system to preform.
If you have to ask why, you'll never understand.
  • MUBster DUBster
« Reply #2 on: March 12, 2010, 10:42:23 am »
Bit of a politicians response... I need more substance!!!
If it was one or the other - which one would you go for?
I have both DVs sitting here with me - well the OEM one is fitted at the moment, just so that I can compare and contrast it to the Forge one I have been running over the past 6 months.
Offline GTIjames
« Reply #3 on: March 12, 2010, 11:43:09 am »
i went from the 'D' valve to the Forge DV - Yellow Spring - it was part of my quest to solve a flat spot - turned out to be the revo settings in the end
i also changed as I heard the noise was a bit fruitier with the forge - which it is when paired with a CAI in particular the ITG.
in terms of performance - forge seems to work well and holds boost solidly but so did the 'd' valve - there is a huge thread over on golfmkv.com comparing the two with logs etc - which shows the D valve works just as well
i like forge stuff though - uk company and their products seem well developed and produced, aftercare is always good too  :happy2:
Offline FamilyDub
  • ...who needs a diesel?
« Reply #4 on: March 12, 2010, 12:35:35 pm »
Unless you're adding loads of bits and a re-map, I'd stick with OEM..
MKV GTI | Reflex Silver | 5-dr, Family-Spec | 17" w/anthracite Finish | Manual | Highline | Cruise | Revision 'D' DV | Dirty Pipes |
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #5 on: March 12, 2010, 01:45:47 pm »
OEM new version all the way , as good as Forge but fit and forget with no maintenance required...
when mine goes thats what I'll be doing  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
Offline wigit
  • -Given: 129
  • -Receive: 42
« Reply #6 on: March 12, 2010, 04:43:56 pm »
just had a rev D put on the rocco after killing the G after 30k
Offline cuprak1
  • Cupra k1 - 360 bhp/360 ft-lbs
    • London web design
« Reply #7 on: March 12, 2010, 04:48:16 pm »
Whats the best price people are managing to get the latest revision DV for?
I can get them for about £52 quid plus postage to the UK..
SpeedStats iPhone app  - AVAILABLE NOW!
View my Cupra k1 project thread here! 360is
Offline wigit
  • -Given: 129
  • -Receive: 42
« Reply #8 on: March 12, 2010, 04:50:01 pm »
£50.29 inc VAT from my dealer today  :happy2:
Offline gazbutS3
« Reply #9 on: March 12, 2010, 04:51:06 pm »
I've tried both, twice, and will stick with the D rev from know on. The Forge 1 works but so does the D rev for a third of the price and much less hassle fitting it. The D rev's been in min for over 10K on stg2+ with no problems at all :happy2:
they are only 40quid from the dealers aren't they? or they were when I got mine :smiley:
Offline KRL
  • -Receive: 29
« Reply #10 on: March 12, 2010, 05:55:09 pm »
Why is the Forge DV more hassle to fit on a K04?
Offline gazbutS3
« Reply #11 on: March 12, 2010, 06:19:51 pm »
On a K04 its the cuttin pipes and finding a suitable place to mount the solenoid etc, the std valve is just a bolt on jobbie :happy2:
On the K03 its even worse, cuttin pipes and all that and its under the car :smiley:
Offline wigit
  • -Given: 129
  • -Receive: 42
« Reply #12 on: March 12, 2010, 09:32:45 pm »
picture of my rev G taken off the rocco today after 29,000 miles, dealer said he couldn't find a boost leak when we agredd to disagree earlier in the week should have gone to spec savers
  • MUBster DUBster
« Reply #13 on: March 12, 2010, 11:28:10 pm »
My dealer refused to acknowledge that the diverter valve had gone - but rather my turbo was on its way out.
I soon put them right...removed the thing and showed them the faulty part... they were speechless!!!  :fighting:
« Reply #14 on: March 13, 2010, 08:36:03 am »
^^^Mo you need a better dealer.
