Author Topic: Another one of those "VW dealer" threads!!  (Read 2853 times)
« on: March 18, 2010, 05:21:03 pm »
Well,
I took the car to my local (and usually good) dealers for it's 3rd yr service. Not much for them to do given the modifications that I have. Basically check the tyre depth, pad wear and a change of oil and filter....don't clean the car or touch the ECU and TCU and make sure they look after it. Can't go wrong there eh?
WRONG!!
The last two services were done with long life oil and it is in my file they have. It specifies long life oil on T7D servicing regime. They had the car for 4 hrs and put in normal semi-synthetic oil  :sick:
The one thing that they had to change to the car and they cocked it up!! :fighting:
Then the service manager says it isn't there fault because I didn't re-specify it for the 3rd service and wanted to charge for the change of oil :surprised:
I have a couple of questions...
I read somewhere that long life oil is used as standard on GTI's anyone confirm or refute this?
I now have semi synthetic oil in the car until next week. I reckon it will be fine running this, but is there anything I should be careful of, like longer warm up times etc (I understand it is 10-40 oil)?
Offline Poverty
  • -Given: 36
  • -Receive: 21
Re: Another one of those "VW dealer" threads!!
« Reply #1 on: March 18, 2010, 06:06:04 pm »
youre running long life schedule on your tuned motor?
Would have thought you would want to change oil more frequently and using 5w-30 fully synthetic?
« Reply #2 on: March 18, 2010, 06:10:50 pm »
as above 10 40 is what i use and have always put it in the car as its never in long enough 8 to 10k with me and yes John its fine
« Reply #3 on: March 18, 2010, 06:18:34 pm »
I'm on time and distance regime (the T7D should be T&D in my first post :ashamed:). I only do around 8k a year maximum and the engine has had an interim oil change last year when the engine was out :happy2:
I have always specified using the 5W-30 synthetic oil  with my dealer even though on T&D, it just happens that my dealer didn't read my requirements before shoving the 10W-40 oil in.
Cheers Matt. :happy2:
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #4 on: March 18, 2010, 06:21:34 pm »
ohhh now I understand  :happy2:
« Reply #5 on: March 18, 2010, 06:28:05 pm »
just make sure they stuck a 1 litre top up in the boot as thats what they should do so u know what make of oil the use  :smiley:
Offline candy turbo
« Reply #6 on: March 18, 2010, 06:46:44 pm »
why dont you do it yourself john , your vw warrenty must be long gone any way ?
« Reply #7 on: March 18, 2010, 06:54:37 pm »
I think it was TT who said LL oil was standard across the range now. If you ask VW UK they should be able to verify this and then you can go and tell your dealership. I would have specified LL oil anyway regardless of whether they know or not.
Offline vwrascal
« Reply #8 on: March 18, 2010, 07:46:31 pm »
Mines booked in on saturday at local dealers for its 3rd service/30,000miles - Im on T&D too.  I asked them to use LL oil and they said thats all they use anyway (shell LL)
« Reply #9 on: March 18, 2010, 08:01:28 pm »
I took out a VW service plan, so it's all paid for now :happy2:
Runs out at the end of March along with the warranty, so I'll be stepping up the modding/ripping out after then :evilgrin:
Offline candy turbo
« Reply #10 on: March 18, 2010, 08:17:05 pm »
i dont do many miles in mine but i change the oil every 6 months , i use castrol edge for vw audi tfsi engines , i m on good terms with castrol techies (from my escort mk 2 rallying days ) and the guy there says this oil will prevent the build up of sh*t the catch can does , cant say it will but has to be worth a try  :happy2:
