April 17, 2025, 05:40:01 am
All Things Mk5
Performance Modifications
Torquing up vis balance shaft delete freewheel?!
Topic: Torquing up vis balance shaft delete freewheel?! (Read 1661 times)
Xcore
Can't Read PM's Yet!
-Given: 0
-Receive: 0
November 10, 2020, 09:35:06 pm »
Is there a guide anywhere on fitting this free wheel? How is it braced to be able to torque it? I assume a dab of blue loctite is advisable?!
pudding
Global Moderator
Just look at my post count
-Given: 2
-Receive: 690
Re: Torquing up vis balance shaft delete freewheel?!
Reply #1 on:
November 29, 2020, 05:27:47 am »
There's a hole in the pump housing to poke a small screwdriver/allen key into to hold the shaft still to torque up the sprocket.
@muff1991
has a picture of it.
Loctite isn't a bad idea. I'd go with the permanent loctite red personally.
All Things Mk5
