Author Topic: Will these brakes fit a Mk5 gti?  (Read 2327 times)
Re: Will these brakes fit a Mk5 gti?
« Reply #1 on: February 06, 2021, 09:41:05 pm »
They are GTI brakes essentially.... are you after an upgrade?
Offline Lewo
« Reply #2 on: February 07, 2021, 08:43:28 pm »
I've got some Mk7r brakes to go on at somepoint, just noticed that these ones have a 57mm piston so would be better than the standard brakes, they have 51mm a piston?
Offline bacillus
  • -Receive: 451
« Reply #3 on: February 07, 2021, 10:38:02 pm »
just be careful as at that price you will have to pay custom duties seeing it's coming from a German seller.
Offline Lewo
« Reply #4 on: February 10, 2021, 01:14:51 pm »
So that works out to around £230 I think if the charges are applied.
Are the standard brakes 51 or 53mm piston?
Offline colesey
  • -Receive: 89
« Reply #5 on: February 11, 2021, 05:43:52 pm »
I thought it was 54mm diameter as standard with 57mm for the R32 calipers and 60mm on the mqb platform R / S3.
Offline Lewo
« Reply #6 on: February 14, 2021, 11:46:57 pm »
Ok cheers.
So I guess these are a kind of halfway house between the standard brakes & S3/R32s?
Offline FatWelshBoy
« Reply #7 on: February 15, 2021, 11:14:55 am »
The 7R brakes are the ones to buy. Every bit as powerful as the R32 setup but a good bit lighter. I didn't measure the piston on mine when fitting them but I'm sure they are 60mm diameter. They provide all the braking power you'll ever need for fast road use (you'd want better again for track use) and the difference over stock brakes is massive.
Offline Lewo
« Reply #8 on: February 15, 2021, 10:52:28 pm »
Yeah I've got some 7r's to put on mine I was just wondering about those I linked to.
  • -Receive: 690
« Reply #9 on: February 19, 2021, 09:19:07 pm »
GTI PP/Cupra R/7.5R/8V S3 calipers + Carriers + pads with appropriate clip-in emblem plate.
Clubsport S 340mm 2 piece discs.
Good value.  Ample stopping power.  OEM Wheels fit over them.  The end.
Leave all the 50pot calipers, Aston Martin Lamborghini Bentley sh1t to the scene queens.  Simply not needed on a FWD Golf.
