April 28, 2025, 01:21:43 am
All Things Mk5
How to Guides / Troubleshooting
Traction Control Light On
Topic: Traction Control Light On (Read 5016 times)
maxamplitude10
Always Involved
-Given: 10
-Receive: 5
'07' ED30 Manual 3Dr
February 25, 2021, 07:35:55 am »
Guys parked up the Ed30 yesterday and
all was well, started it this morning and the traction light is on.
Any common causes i should be investigating to begin with?
Max
mjmallia
Won't Shut up.
-Given: 3
-Receive: 58
Re: Traction Control Light On
Reply #1 on:
February 25, 2021, 07:51:44 am »
Any dash lights on, as I had three on mine when I had a faulty rear sensor/magnetic ring.
Maybe plug into VCDS to get some codes.
Mike
South Coast
S3 8L ---- Golf Mk4 GT TDI ---- Lupo GTI ---- A4 B6 Sline ----
Golf Mk5 GTI
GVK
Won't Shut up.
-Given: 1
-Receive: 69
Reply #2 on:
February 25, 2021, 08:42:06 pm »
Strange to just have the traction one on.
If there's an ABS fault you usually get the 3 as above!
ABS/Traction/TPMS.
Scirocco TDI GT
https://www.facebook.com/groups/gvkmotorsport
maxamplitude10
Always Involved
-Given: 10
-Receive: 5
Reply #3 on:
February 27, 2021, 12:06:25 am »
Yes only yellow traction light on dash, very odd......It's like the traction button has been pressed to turn it off?
I will plug it in over the weekend hopefully and see whats stored in codes.
Max
maxamplitude10
Always Involved
-Given: 10
-Receive: 5
Reply #4 on:
March 05, 2021, 06:35:34 pm »
Update, just plugged into computer and have the following code:
059 B - Brake Pressure Sensor (Electrical Fault In Circuit)
Any ideas guys?
Cheers Max
pudding
Global Moderator
Just look at my post count
-Given: 2
-Receive: 690
Reply #5 on:
March 05, 2021, 08:26:22 pm »
It will either be the brake light switch (behind the brake pedal) or the brake pressure sensor, which should be screwed into the ABS pump.
maxamplitude10
Always Involved
-Given: 10
-Receive: 5
Reply #6 on:
March 05, 2021, 10:14:17 pm »
Pudding is the pressure sensor available separately from the ABS pump itself then?
I'll check both items tomorrow and feedback any findings..
Thanks again
Max
pudding
Global Moderator
-Given: 2
-Receive: 690
Reply #7 on:
March 05, 2021, 11:44:21 pm »
Hmmm, looks like the pressure sensor is actually built into the ABS pump
https://www.actronics.co.uk/acinsights/ate-mk60
GVK
Won't Shut up.
-Given: 1
-Receive: 69
Reply #8 on:
March 05, 2021, 11:48:07 pm »
Back in the day when I worked at VW this fault under warranty was a case of checking MVB for brake light switch input then if that was ok , new ABS pump.
Nowadays can get them repaired by people like BBA reman. ECU testing etc.
https://www.mk5golfgti.co.uk/forum/index.php/topic,131407.msg1146552.html#msg1146552
As in above thread I have seen this fault so common in Ford/VW/BMW when working in the main dealers.
Last Edit: March 05, 2021, 11:56:21 pm by GVK
Scirocco TDI GT
maxamplitude10
Always Involved
-Given: 10
-Receive: 5
Reply #9 on:
March 06, 2021, 08:11:09 am »
Guys thanks for the input, after further investigation and collecting some live data I have come to the conclusion the abs pump is knackered. I have a constant reading of 214 BAR from pressure sensor which doesn't change when brake pedal is pressed and it also seems like an insanely high pressure to have in a braking system!!!!!!
Also after some googling as GVK states this seems to be a common issue..... Time to get the toolbox out again
Cheers Max
pudding
Global Moderator
-Given: 2
-Receive: 690
Reply #10 on:
March 12, 2021, 07:03:03 pm »
A good excuse to upgrade to the MK6's XDS pump
I don't know how involved it is though!
All Things Mk5
