Author Topic: What stereo is in your mk5?  (Read 18364 times)
Offline OldGTI
Re: What stereo is in your mk5?
« Reply #45 on: March 19, 2021, 01:26:24 pm »
I took a pic of my dash and sent to the seller in aliexpress, he recommended I buy https://www.aliexpress.com/snapshot/0.html?spm=a2g0s.9042647.0.0.469a4c4dzv7k5g&orderId=8127093897738746&productId=32888260904 along with the RCD330.
Thanks - was there a reason why you went for the 330 and not the 360 Pro?
I'm looking for a friend and think I might be missing something!
[/quote]
I think I did end up with the 360 pro as as far as I could tell it is pretty much the same unit. I just did not want to complicate things as most people speed read posts. It is a great unit I have Waze running on it and all my calls, texts etc are right there. No issues at all. Two of my fiends also bought them and love them.
Offline akbarirfan
  • -Given: 81
« Reply #46 on: March 20, 2021, 12:02:48 pm »
Thanks - seriously considering this as it really modernises functionality.
Just need to check regarding Gateway etc - it used to be simple a few year back when all I needed to do was swap the live and switched live pins over (yellow and red)!!
Offline MKMike
« Reply #47 on: April 16, 2021, 07:05:07 pm »
finally installed the RCD330 unit all went well, that is until I switched it on and only the left passenger speaker is actually producing any sound. Gonna have to take it out again to see if I clipped everything in properly. Anyone had this problem?
Offline MKMike
« Reply #48 on: April 17, 2021, 10:36:30 am »
Took it all apart and reconnected again and now it works. My suggestion to anyone doing this, test it when all the trim is out and don't be a softlad like me and put it back together and then switch it on.
Offline mirelxxl
  • Newbie
« Reply #49 on: January 29, 2022, 05:45:44 pm »
Hi there. I am about to buy a Kenwood dmx5020bts and I was wondering if you had steering wheel controls or you had to buy a separate controller module. Thanks
Offline steve4934
« Reply #50 on: January 29, 2022, 08:06:50 pm »
While we’re here, can anyone recommend a decent DAB aerial, I brought a cheap 15 quid one off eBay and it’s awful anywhere there’s not a really strong signal.
Offline TimW
« Reply #51 on: January 29, 2022, 11:50:18 pm »
I’ve got no idea what mine is? Perhaps from a mk6? It has no DAB, Bluetooth and is pretty dull!
Any recommendations  for replacement with CarPlay either oem retrofit or aftermarket.
