March 31, 2025, 07:32:49 am
All Things Mk5
Mk5 General Area
Rough / Surging Idle
Topic: Rough / Surging Idle (Read 898 times)
Mark_DF05
Always Involved
-Given: 23
-Receive: 9
March 02, 2021, 12:44:21 pm »
Hi all,
having a few issues with the car again - random rough idle and surging. Seems to be when warm only. EML isn't on and no fault codes are present when scanned (carista), PCV seems to be fine (R revision) and it's just had a fresh set of plugs. Decided to get a smoke test yesterday whilst it was in for a service which revealed a tiny leak in the below hose. Mechanic didn't seem to think that would cause such a bad misfire but going to replace it first before taking it to a specialist who can diagnose with vcds and provide a bit more detail. Don't suppose anyone knows the part number (can't make it out in the pic) or has had similar issues?
ROH ECHT
Just look at my post count
-Given: 113
-Receive: 149
K04 PLAY....ZOOM DIS!
Re: Rough / Surging Idle
Reply #1 on:
March 02, 2021, 04:02:57 pm »
This is it: 06F 133 781 L
There's one thing I am unsure about and that is; 06F 133 781 L is for the rear EVAP canister...and I do not know if the same tubing is used if you have the front EVAP canister.
K04 PLAY...K04 turbo/S3 INJ. & FMIC/FORGE FMTC, TB hose, & WG actuator/GIAC's H.O. K04 & DSG TUNES/AWE DV/NEUSPEED P-FLO,TURBO OUTLET & TB pipe/AUTOTECH hpfp/BSH Eng.&Trans Mounts/H&R ARB's/Whiteline Performance springs & W.A.L.K./ECS stage-3 BBK/BILSTEIN B8's...ZOOM'DIS...GIAC K04 tune-2007 Volkswagen GTI: 12.823 @ 112.050 MPH__Voting for my Dragtimes link:
http://www.dragtimes.com/Volkswagen-GTI-Timeslip-25700.html?r=1
Mark_DF05
Always Involved
-Given: 23
-Receive: 9
Reply #2 on:
March 02, 2021, 04:44:09 pm »
Great thanks, I'll check and get one ordered
All Things Mk5
Mk5 General Area
