Author Topic: Starting issues, cranks no start?  (Read 8543 times)
Offline Vsandhu15
« on: March 11, 2021, 09:35:29 am »
Hi guys wondering if you could help me! So my golf turns over and does not start, have replaced coil packs, high pressure fuel pump, fuel rail pressure sensor replaced and camshaft sensor replaced still no start? When turning the engine it emits white smoke from the exhaust and even when applying easy start it does not take it in its like it spits it back out? Please help me im so confused! Thanks
Offline DBXdarkangel
  • -Given: 18
Re: Starting issues, cranks no start?
« Reply #1 on: March 11, 2021, 11:24:18 am »
Get it on vcds, read codes and post back here.
Offline GreigC
« Reply #2 on: March 11, 2021, 02:03:17 pm »
When did you last check your cam follower? Hopefully thats not broken and wrecked your fuel pump/cam... As above codes would be best.
« Last Edit: March 11, 2021, 02:15:53 pm by GreigC »
Offline Vsandhu15
« Reply #3 on: March 11, 2021, 06:18:53 pm »
There is 0 fault codes!?!? And when i unplug cam sensor and try to start the ecu does not throw up any fault codes but when unplug air mass it throws fault code.
Offline GVK
  • -Receive: 68
    • GVKmotorsport
« Reply #4 on: March 11, 2021, 09:14:21 pm »
Turbo fell apart?
Offline Vsandhu15
« Reply #5 on: March 12, 2021, 12:20:46 am »
Turbo has been checked and is fine! Im so confused it just turns over dont even try to fire :thinking:
Offline titchy
« Reply #6 on: March 12, 2021, 09:35:27 am »
compresion test and vcds
Online Octoparrot
  • -Receive: 103
« Reply #7 on: March 12, 2021, 09:56:13 am »
Immobiliser issue?
Offline Vsandhu15
« Reply #8 on: March 12, 2021, 11:00:12 am »
Compression is fine, immobiliser seems to be fine aswell. Its so strange it turns over and dont fire with 0 fault codes driving me insane now
Offline mjmallia
  • -Receive: 57
« Reply #9 on: March 12, 2021, 12:13:17 pm »
Checked all the fuses?
Does it make the priming noise when the drivers door is opened?
Mike
South Coast
  • -Given: 18
« Reply #10 on: March 12, 2021, 02:58:52 pm »
Are you sure the plugs are sparking and are you sure there's fuel getting to the plugs from the injectors?
Offline GVK
  • -Receive: 68
    • GVKmotorsport
« Reply #11 on: March 12, 2021, 03:15:24 pm »
Smoke from the exhaust I would be concentrating on, it has to be oil from the engine or turbo, or coolant.....
Basics, how are the levels?
« Last Edit: March 12, 2021, 03:18:08 pm by GVK »
Offline Vsandhu15
« Reply #12 on: March 12, 2021, 11:48:28 pm »
I have checked the fuses under the bonnet and on driver side door all seems to be fine! Fuel pump has been checked and is working fine?
Offline Vsandhu15
« Reply #13 on: March 12, 2021, 11:49:12 pm »
I cant be so sure but my mechanic has said all is fine here
Offline Vsandhu15
« Reply #14 on: March 12, 2021, 11:50:23 pm »
All levels are fine turbo has been checked and is fine too! Im so fed up now
