April 22, 2025, 04:11:36 am
All Things Mk5
How to Guides / Troubleshooting
Poor idle
Topic: Poor idle (Read 1686 times)
Octoparrot
Just look at my post count
-Given: 8
-Receive: 103
Poor idle
July 02, 2021, 10:30:02 pm »
My car has suddenly started idling poorly, got a code from vcds of p2279 air leak, does this sound like a failed pcv valve?
pudding
Global Moderator
-Given: 2
-Receive: 690
Re: Poor idle
Reply #1 on:
July 02, 2021, 11:46:33 pm »
That is certainly a potential culprit. If the PCV valve is stuck open, it will definitely cause an air leak.
JoshB
Always Involved
-Given: 4
-Receive: 7
Re: Poor idle
Reply #2 on:
July 11, 2021, 08:56:04 am »
I think P2279 is to do with your diverter valve. Does it pull alright?
Getting too old for this...
GVK
Won't Shut up.
-Given: 1
-Receive: 69
Re: Poor idle
Reply #3 on:
July 11, 2021, 08:59:11 am »
is intake air leak so check the PCV, the PCV gasket and the brake servo pipe work. Spray WD40 at the suspected leak and the engine will suck it in raising the idle.
Scirocco TDI GT
https://www.facebook.com/groups/gvkmotorsport
JoshB
Always Involved
-Given: 4
-Receive: 7
Re: Poor idle
Reply #4 on:
July 11, 2021, 09:02:15 am »
This might help
https://www.obd-codes.com/p2279
Octoparrot
-Given: 8
-Receive: 103
Re: Poor idle
Reply #5 on:
July 11, 2021, 11:35:55 am »
Well I deleted the code and it hasn't come back, the car ran fine all this week but I have changed the pcv and gasket just in case. The pcv was the original but seemed to be working fine when removed. Odd
GVK
Won't Shut up.
-Given: 1
-Receive: 69
Re: Poor idle
Reply #6 on:
July 11, 2021, 01:00:22 pm »
it's fixed, carry on
Scirocco TDI GT
All Things Mk5
Poor idle
Jump to:
=> How to Guides / Troubleshooting
