Author Topic: Possible Turbo Failure - Please Help  (Read 1328 times)
Offline Jearum
« on: September 20, 2021, 10:13:16 am »
Hello,
I own a Mk5 GTI Edition 30 (08 plate) with 108k on the clock. Recently it failed its MOT when they ran the emissions test as they reported the garage filled up with smoke. The garage had previously checked the car due to me reporting that it was using a lot of oil but no leaks were found. I have since had it looked at by a local VW dealer and they report back that they are 90% sure it is the turbo that is at fault (they showed me a picture with oil on the turbo). They have carried out a health check and also spent time on other tests. My problem now is that they are quoting me £2.5k to supply and fit a new turbo. The other option they have offered me is to take my old one off completely to check it definitely is the turbo but to do that and put it back on is £1.3 k. I don't have any issues when I drive the car, no loss of power or large amounts of smoke coming out the back and the VW diagnostics test they ran shows no other faults. I have looked around to see if I can source a turbo unit myself but haven't seen many options and Euro Car Parts have told me they don't stock it either. I feel at this point in time I am not left with many options and it may be the end of the road for my car.
I wondered if anyone had any thoughts on this?
Cheers Ben
Offline T777_GTI
Re: Possible Turbo Failure - Please Help
« Reply #1 on: September 20, 2021, 11:34:06 am »
Hi, I can't really say what's wrong with the car as I'm not hugely mechanical but be careful of what the vw dealer says. Alot of the time they try to con you into buying a new turbo. Told me that I needed a new turbo when it was just the actuator which is replaceable. I also know of others who have had similar problems and have been told new turbo. Make sure you try a few other garages and see what they think.
Offline Clarkj93
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php/topic,131272.0.html
« Reply #2 on: September 20, 2021, 11:53:14 am »
I'd probably be on the phone to r-tech performance now or another well known tfsi tuner, bet you they could take it off get it refurbed and tune it for not far a decent rate, that all seems awfully expensive.
  • -Receive: 690
« Reply #3 on: September 20, 2021, 01:13:51 pm »
If the workshop filled up with smoke, it sounds pretty definitive to me. Turbo oil control rings gone.  A new genuine borg weiner k04 can be sourced for a grand in the aftermarket.
Offline Mekaniko
« Reply #4 on: September 20, 2021, 02:13:56 pm »
Check your rocket cover for no leaks, a colleague of mine changed the turbo due to that
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #5 on: September 21, 2021, 09:05:08 am »
My suggestion would be to take you car to a reputable VW specialist/Tuner so you get to deal with experts and avoid those deal prices.
  • -Receive: 690
« Reply #6 on: September 23, 2021, 06:54:26 pm »
It’s not the rocker cover gaske or dealers swindling people, the turbo is f’cked. These engines don’t belch out blue/white smoke for any other reason.
