Author Topic: Knock & Creak from rear  (Read 1624 times)
Offline Jons1001
« on: September 20, 2021, 12:10:30 pm »
Hi all,
I have a a knocking noise and creaking from the rear of the car which seems to become apparent when the car is warmed up. The creaking seems to be worse when braking. I had the car the suspension checked and they said everything was fine and it would pass an mot no problem. Any ideas what this could be? maybe rear anti roll bar bushes and they have missed it? or could it be a steering rack problem? Thanks
edit : forgot to add it has a dogbone mount insert fitted aswell, could this cause a knocking/creak that sounds like its from the rear? Just strange how it seems to only start once the car is warmed up.
« Last Edit: September 20, 2021, 12:17:00 pm by Jons1001 »
Offline GVK
  • -Receive: 68
    • GVKmotorsport
Re: Knock & Creak from rear
« Reply #1 on: September 20, 2021, 03:53:26 pm »
I had my rear pads creaking one year when hot, removed rear pads cleaned up mating surfaces and copper slipped, was fine.
Offline Jons1001
« Reply #2 on: September 20, 2021, 04:04:59 pm »
Hmm that's a good shout, will get it checked. Take it that wouldn't also cause any knocking though?
Offline GVK
  • -Receive: 68
    • GVKmotorsport
« Reply #3 on: September 20, 2021, 05:20:43 pm »
Check the stoneguards havent rotted through too
Offline mjmallia
  • -Receive: 57
« Reply #4 on: September 21, 2021, 07:14:18 am »
The rear creaking I had recently were my rear ARB bushes.  Removed the brackets and re-greased them.........all quiet again, so another possibility.
Mike
South Coast
