Author Topic: Yellow dipstick - check yours  (Read 6967 times)
Offline LC5F
  • -Receive: 80
Re: Yellow dipstick - check yours
« Reply #15 on: March 12, 2022, 03:27:41 pm »
It could be some fiendish Wolfsberg engineering to provide a place for a small leak to keep vacuum from spiking???
I'm tempted to change mine too @Pudding what are the specs for the O-ring you got?
  • -Receive: 690
« Reply #16 on: March 14, 2022, 08:40:23 am »
God knows!  Reminds me of my old VR6 oil filter that had an O - ring on it, which served absolutely no purpose!
I just used the ones in the link - https://www.amazon.co.uk/dp/B07CVHLBYJ/ref=pe_27063361_487055811_TE_dp_1
Online jacksosi
« Reply #17 on: March 22, 2022, 11:00:45 pm »
We never touch ours, isn’t that is what the oil warning light is for?
May I show you my ring (oooh matron!) ?
Are there bits missing?
What replacement should I buy?
Black MkV Gti (Nov 2008), no modifications
  • -Receive: 690
« Reply #18 on: March 23, 2022, 09:00:21 am »
 :doh:
Online jacksosi
« Reply #19 on: March 23, 2022, 10:24:02 am »
 :doh:
Ok, well she's done 95k trouble free miles with that approach, and drives lovely, so  :P
Any thoughts on my Qs?
 - Are there bits missing?
 - What replacement should I buy? ...or perhaps I just need to add an O ring?
Offline LC5F
  • -Receive: 80
« Reply #20 on: March 23, 2022, 10:33:14 am »
Yes - there is bits missing from your dipstick and will be in the sump -the missing part would hold the o-ring
At the very least replace the dipstick, but consider the tube as well.
BTW - my low oil warning doesn't work, so don't just rely on that.
  • -Receive: 690
« Reply #21 on: March 23, 2022, 12:34:33 pm »
Yup.
Low oil also increases the potential for running bearings dry round fast sweeping corners.
Online jacksosi
« Reply #22 on: March 23, 2022, 05:20:58 pm »
There seem to be lots of places selling replacements, where are you guys getting then from so I don't buy a dud?
I have found this one for example : https://www.autodoc.co.uk/ridex/15783237
Offline GreigC
« Reply #23 on: March 23, 2022, 06:50:27 pm »
These guys only sell genuine parts:
https://www.coverdalecarparts.co.uk/product-page/2-0-tfsi-dipstick-06f115611f
Also where I got mine.
Offline mjmallia
  • -Receive: 57
« Reply #24 on: March 24, 2022, 07:45:58 am »
I go direct to the source, which is TPS for the VW Group.
Use link to find a local dealer. Some are non trade friendly
Mine is in Poole, but I know them all there being an ex HQ employee
https://tps.trade/
They supply trade and also the VWG Dealerships
« Last Edit: March 24, 2022, 07:49:24 am by mjmallia »
Mike
South Coast
Offline Dann
« Reply #25 on: March 24, 2022, 09:30:52 am »
Should probably check mine.
I've not actually checked the oil once since I bought it back in December (it was serviced in Jan)
But then again, it's not even used a tank of fuel since then
Online jacksosi
« Reply #26 on: March 24, 2022, 10:40:31 am »
Actually, bearing in mind the bits have already fallen off, is is better to just leave it rather than buying another and risking parts of one that falling off too?
I guess that comes back to the original point of is the seal good enough  :thinking:
Offline mjmallia
  • -Receive: 57
« Reply #27 on: March 24, 2022, 11:06:37 am »
With the dipstick marginally out on mine, the engine idle is crap.
The system is in a vacuum state and any leaks will affect the efficiency of the engine.
Mike
South Coast
  • -Receive: 690
« Reply #28 on: March 24, 2022, 11:27:37 am »
Oil level checking should obviously be proportional to the car's use, so that's fine.  Well done for actually providing some context, which people rarely do one forums  :happy2:
I do 500 miles a week, so I check the oil once a month......hence spotting things early, like crumbling dipsticks.
  • -Receive: 690
« Reply #29 on: March 24, 2022, 11:33:49 am »
Bits are in the sump and you have a vacuum leak, which you seem completely indifferent about, but keep posting about it regardless.  God people are weird these days.
