Author Topic: P0373  (Read 2755 times)
Offline frasermk5
P0373
« on: April 25, 2022, 10:28:56 am »
I have a P0373 code when scanning for fault codes, the car sometimes seems a bit jumpy almost like it skips a beat when idling. Rough cost to fix?
  • -Receive: 690
Re: P0373
« Reply #1 on: April 25, 2022, 03:47:21 pm »
Maybe if you told us what P0373 actually relates to, someone might know.
Offline frasermk5
Re: P0373
« Reply #2 on: May 06, 2022, 10:41:45 pm »
“ Timing Reference High Resolution Signal A Intermittent/Erratic Pulses”
Not sure if that’s any help, can’t seem to find any posts about anyone having this code, the symptoms seem to be a rough startup and a slight lumpiness / misfire on idle.
  • -Receive: 690
Re: P0373
« Reply #3 on: May 07, 2022, 12:40:23 pm »
Was that checked with a generic scan tool?  I haven't seen that error before. Maybe VCDS will translate it better if you know someone who has it?
