Author Topic: One reason why fuel-rail pressure may be low....  (Read 5443 times)
  • -Receive: 690
Re: One reason why fuel-rail pressure may be low....
« Reply #15 on: May 19, 2022, 09:11:17 am »
56K is nothing, although it's not necessarily mileage/age related, but rather maintenance, or lack thereof that causes it.
Offline adamvaughan
« Reply #16 on: May 19, 2022, 10:29:13 am »
I'll sleep peacefully for a while then.  :happy2:
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #17 on: June 20, 2022, 04:48:44 pm »
I just got these pics from one I helped for having a persistent P0087 after replacing everything.
I posted the tri-lobe specs and he checked his and found he needed a new cam. When swapping the cam he posted these pics. It is obvious his replacement is slightly used, but measures well at 42.5 mm.
I wanted to share what just a bit over 1.5mm of wear looks like:
Offline JettaJ
  • Newbie
« Reply #18 on: October 08, 2024, 10:10:21 pm »
Sorry for resurrecting an old post but I have been chasing the P0087 code for a while now and pulled the HPFP and measured the lobes vs the base circle and am getting a lift of 4.6, 4.6 and 4.8 that is wore but not nearly what I have seen in other posts here. Does anyone know the wear tolerance? I have changed the bucket every 15k since I purchased the car (68k miles) and the original had very little wear. currently at 115k miles.
71 standard beetle 1800cc - currently in pieces
91 GTI 16v - cannibalized for Jetta and sold
97 Jetta GT converted to ABA 16v - sold
2007 - GTI current source of hair loss
