Author Topic: Clicking/Ticking noise from glovebox  (Read 2313 times)
Offline Jons1001
« on: May 01, 2022, 08:31:25 pm »
Anyone else got this? Looking online it seems it could either be fuel lines (but this would only be at idle? Mine is when driving) or possibly something to do with the AC. It's really getting on my nerves now, anyone managed to get rid of it?
Offline maple
  • Newbie
Re: Clicking/Ticking noise from glovebox
« Reply #1 on: May 01, 2022, 10:35:01 pm »
I removed my glovebox half a dozen times, the central heater vents and radio to try and find the source of a rattle, ticking and squeak that was driving me nuts for six months or so. This also appeared to be coming from the glovebox area. It really ruined the driving experience to the point of nearly selling the GTI. A trusted friend came out with me on a drive and poked around to discover the hydraulic brake control unit (behind the battery) had a worn rubber mount which was causing a sound to transfer from the chassis to the cabin. Might be worth checking out.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=2789n6cmjon2u8quqpjfteaiok&/topic,19740.0.html
« Reply #2 on: May 01, 2022, 11:04:44 pm »
It's probably the stepper motor for the climate  adjusters.
Offline Sebas_theFish
« Reply #3 on: May 02, 2022, 01:55:07 am »
Would be the AC flap motors. Quite common for them to make noise, not necessarily anything wrong with them.
Sent from my Samsung Smart Fridge
Offline Clarky
« Reply #4 on: May 02, 2022, 09:49:47 am »
Mine does it too....was told it’s not really anything to panic about so I don’t! If you want to prove it is that then as soon as you hear the noise turn the climate control to off...if it stops then bingo! If it carries on then you got bigger issues....Golf life
« Reply #5 on: May 02, 2022, 12:30:55 pm »
A VW tech once described it to me as "woodpecker noises behind the dash".
Offline Jons1001
« Reply #6 on: May 02, 2022, 05:47:17 pm »
Hmm, mine does it when the climate is off. It's there all the bloody time!
Offline Clarky
« Reply #7 on: May 02, 2022, 07:05:50 pm »
wellety wellety well.....maybe when the ticking stops is the time to panic! Boom!
Offline OllieVRS
« Reply #8 on: May 02, 2022, 08:10:46 pm »
I've had this since I got my car 9 months ago. Also clicks randomly a few times here and there with the fans/aircon on or off. Goes extra clicky when turning the temperature up or down.
As long as it's not engine related I'm not too bothered.
'06 Skoda Octavia vRS TFSI
« Reply #9 on: May 03, 2022, 02:17:07 pm »
as.mentioned the motor on the heater box will be faulty as the teeth wear out
  • -Receive: 690
« Reply #10 on: May 04, 2022, 12:23:54 pm »
I've given up caring about the myriad noises these cars make.  So long as it moves and stops, that'll do.
Offline Ghoraxz
  • Newbie
« Reply #11 on: September 10, 2023, 09:24:49 pm »
Hi Guys, one question.
What do you think about? Is it okay?
After changing timing, belt, water pump, wheels, cam chain, oil pump chain, tensioners, etc, everything in there.
The result you can see in picture.
Hadnt and have not any fault codes. It was just a prevention, changing eveything, bcs its stage 2, so sometimes it gets bombs :D mk5 gti bwa 2007 329k km 🤣
Thanks for your reactions!
« Last Edit: September 10, 2023, 09:46:48 pm by Ghoraxz »
Offline OllieVRS
« Reply #12 on: September 20, 2023, 12:37:01 am »
840RPM idle doesn't seem right, was the engine up to operating temperature? These readings should be taken on a fully warmed up engine.
Normally in Group 093 the range of Phase Position Bank should be 0 to -2KW for a new timing chain kit, -3 to -4KW for a used one and -5 up to -6KW for one that needs to be changed. Anything more (technically less) and you're in the danger zone.
I have no idea why your reading is a positive value.
