Author Topic: Cam follower question  (Read 1307 times)
Offline St282
« on: May 17, 2022, 03:54:57 am »
I changed my cam follower at around 14,000K and it doesn’t seem to have any scratches on it? Black costing untouched. Looks new. Is this normal? Cleanest ive jad when changing are scratches all over.
Offline St282
Re: Cam follower question
« Reply #1 on: May 17, 2022, 04:20:18 am »
Offline mjmallia
  • -Receive: 57
« Reply #2 on: May 17, 2022, 09:28:18 am »
Looks new, so would say you have a very happy cam
Mike
South Coast
Offline St282
« Reply #3 on: May 17, 2022, 10:39:36 am »
I just find it odd cos usually i get scratches from center out when changing at around 14-15k. This is first ive seen it untouched. Hope its a good sign been using ceratec on every oil change in the past 2 years. Maybe that helped?
  • -Receive: 690
« Reply #4 on: May 17, 2022, 10:55:24 am »
There is a slight taper in the cam lobe to force the tappet to spin around, which prevents localised wear spots.   If you don't see the circular wear pattern, either the DLC coating hasn't worn down enough for you to see it - a good thing, or the follower isn't spinning - a bad thing.
Offline St282
« Reply #5 on: May 17, 2022, 11:28:36 am »
Fingers crossed coating hasn’t worn down enough for me to notice anything. Would there be any symptoms if so?
  • -Receive: 690
« Reply #6 on: May 17, 2022, 03:24:17 pm »
Not in the short term but keep an eye it because if you never see the round wear marks, the cam lobe is wearing down.  Once that happens, you start running into fuel cuts in boost.
Offline St282
« Reply #7 on: May 17, 2022, 04:24:26 pm »
Ok. Maybe ina couple thousand miles ill have a peek. But at what distance should it start show wear? I can only imagine checking halfway through interval change
