Author Topic: Charcoal Canister  (Read 2996 times)
Offline TheBALDpuma
Charcoal Canister
« on: September 06, 2022, 06:04:44 pm »
My EML came on a few days ago and I dropped it at a local garage today. They've told me it's a charcoal canister that has got to the end of its useful life and needs replacing. Apparently 2 - 2.5 hours work and a few hundred £££ for the part. Total quote is £483.  Feels a lot - is this normal?
Offline TheBALDpuma
Re: Charcoal Canister
« Reply #1 on: September 06, 2022, 06:16:24 pm »
Looking on the internet it seems the part is under £100 and fitting is a super quick job. I'm sure the guy on the phone said it was a long job because they had to take some bits of to get to something (I should pay more attention).  Could there be a longer job around the same problem (definitely mentioned evap and charcoal canister)
Offline Clarkj93
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=uan1pg6t544qbcjvvnl4ri0bht&/topic,131272.0.html
« Reply #2 on: September 06, 2022, 06:57:58 pm »
Not done it myself but looks dead easy to fit, easy to access too and pretty sure the part is around 100 quid. Should find out what the error code is or what it says. Sounds like you're being taken for a ride or you've misunderstood them.
Offline coolhandluke
  • -Given: 28
« Reply #3 on: September 06, 2022, 07:04:09 pm »
I had the same issue when I had my MK5, I took a punt on a Chinese charcoal cannister and it worked fine. EML light went out after I fitted it. It took 5 mins to fit so I've no idea what your garage is taking about. I'd avoid them.
« Last Edit: September 06, 2022, 07:05:42 pm by coolhandluke »
Offline TheBALDpuma
« Reply #4 on: September 06, 2022, 07:23:55 pm »
It's a garage I've used before and have been fine, and a garage that's been recommended in here before too.  I'm going to ring them in the morning and see what they've got to say about it.
Did anyone know where I can get a genuine part price from. When I Google the part number is only eBay stuff I can see
zsb 1ko 201 801 e
Offline Clarkj93
« Reply #5 on: September 06, 2022, 07:26:57 pm »
zsb 1ko 201 801 e
Call up VW parts and they'll tell you the price of it.
  • -Receive: 690
« Reply #6 on: September 07, 2022, 08:38:17 am »
2.5 hours work?  :grin:
I don't think they even lifted the bonnet and just assumed it's buried at the back near the fuel tank like most other cars.  Utterly ridiculous to charge any more than 30 mins labour for that job.
The can itself was about £120 from VW when I got one.
Offline TheBALDpuma
« Reply #7 on: September 07, 2022, 08:58:20 am »
So they've said that a load of pipes and valves needed all changing because the canister has been superseded. I've spoken to VW and apparently that's only on an audi. And your right £120 from VW.
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #8 on: September 07, 2022, 09:05:00 am »
This is also what I did. My cheap ebay cannister has been on the car for maybe three years now with no issues, cost me about £20 for the part.
Offline TheBALDpuma
« Reply #9 on: September 07, 2022, 09:20:32 am »
eBay canister is an option - but - I'd rather have an OEM one and peace of mind, even though it's loads more expensive.
The way I feel about Chinese eBay specials is that it's a bit of pot luck. You might get lucky and all is fine. But equally you might not. So you pays your money and you takes your chances.
Offline mjmallia
  • -Receive: 57
« Reply #10 on: September 07, 2022, 09:59:05 am »
I recall getting quite a late second hand one from a Sirocco 2013 if I recall and fitted that........been fine since.
A very quick and easy change
Mike
South Coast
  • -Receive: 690
« Reply #11 on: September 07, 2022, 11:16:57 am »
Yeah exactly.  I don't put cheap crap on cars that I do 20K+ miles a year in  :grin:  There is absolutely no way on earth the Chinese canisters use the same quality activated charcoal pellets as VAG do in theirs.
Offline TheBALDpuma
« Reply #12 on: September 07, 2022, 12:57:45 pm »
Any recommendations for an OBD reader? Could have saved myself some hassle
Offline akbarirfan
  • -Given: 81
« Reply #13 on: September 07, 2022, 01:29:51 pm »
Surely it's just a case of pulling the cannister off the braket by the drivers side headlight, undo the 2 or so hose clamps and switching out the cannisters.
  • -Receive: 690
« Reply #14 on: September 07, 2022, 01:39:13 pm »
Plenty of generic ones to choose from, but none of them can read fault codes or live data properly, except OBD11.
If you only intend on scanning a maximum of 3 VAG cars, my recommendation is VCDS enthusiast @ $199 - https://store.ross-tech.com/shop/vchv2_ent/
