Author Topic: Need a few bolt part numbers  (Read 817 times)
Offline OllieVRS
  • -Given: 17
« on: May 12, 2023, 01:08:48 pm »
Hi all, lost a few bolts and damaged a few while currently fixing my low oil pressure issue and it'd be great if someone could help me out with some part numbers. I can't find them via any diagrams online.
I need numbers for:
- Screws holding the PCV (lost one)
- T25 torx bolts with washers holding the intercooler pipe to the sump (both stripped)
- Bolt connecting to bottom of front intercooler pipe to block? (lost long ago)
Picture of the T25s from Pelican guides, labeled yellow:
And the front intercooler to throttle body pipe bolt, unsure what bolt type, just behind the oil filter housing.
Thank you :)
« Last Edit: May 12, 2023, 01:12:54 pm by OllieVRS »
'06 Skoda Octavia vRS TFSI
Offline OllieVRS
  • -Given: 17
Re: Need a few bolt part numbers
« Reply #2 on: May 12, 2023, 04:49:00 pm »
https://volkswagen.7zap.com/en/rdw/golf+variant+4motion/golf/2006-474/1/103-103080/
https://volkswagen.7zap.com/en/rdw/golf+variant+4motion/golf/2006-474/1/145-145095/
You are a legend mate, didn't just tell me the numbers but also gave me a place to find even more of them  :happy2: Thanks!
EDIT: that one for the front boost/intercooler pipe is wrong, RHD is different I think from the one you sent?  But it doesn't have that Y connector part for the DV location since mine's K03, confusing. Nr 35 anyway https://volkswagen.7zap.com/en/rdw/golf+variant+4motion/golf/2006-474/1/145-145097/
« Last Edit: May 15, 2023, 02:13:09 pm by OllieVRS »
