Author Topic: My fuel gauge doesn’t work  (Read 2204 times)
Offline Russboy
« on: June 15, 2023, 07:57:39 am »
  So I got my 1st mk5 gti a few days ago. Refuelled it and now the fuel gauge is stuck on fuel. Can anyone help
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
Re: My fuel gauge doesn’t work
« Reply #1 on: June 15, 2023, 11:00:40 am »
I assume you've done enough miles to know that the guage should be reading less than full?
Access for the intank pump/fuel level float is under the rear bench seat. You could check if the float is stuck and free it if that's the case.
Offline Russboy
« Reply #2 on: June 15, 2023, 11:08:03 am »
The fuel gauge dropped to zero after a few miles, I turned the car off and on again and it went back to full, and it’s not dropped since. I’ve done about 40 miles and it’s not moved at all. :( also the digi fuel gauge still reads 335 miles to fill up.
« Last Edit: June 15, 2023, 11:11:00 am by Russboy »
Offline OllieVRS
« Reply #3 on: June 30, 2023, 02:23:59 pm »
Have you done a VCDS or another OBD2 scan for error codes?
'06 Skoda Octavia vRS TFSI
  • -Receive: 690
« Reply #4 on: June 30, 2023, 09:27:12 pm »
It'll either be the level sender on the pump housing (most likely) or the gauge itself (less likely).
Offline Russboy
« Reply #5 on: June 30, 2023, 09:31:08 pm »
 Thanks allot for your help everyone, by Monday fingers crossed I will know how much fuel I will have In the car.
  • -Receive: 690
« Reply #6 on: June 30, 2023, 09:34:56 pm »
Pop the pump out and with the ignition on, move the float by hand and see if the gauge moves accordingly.
