Author Topic: Engine oil.  (Read 1475 times)
Offline Stehanratty7
  • Newbie
Engine oil.
« on: July 03, 2023, 08:31:56 am »
How’s things, recently bought a MK5 GTI, just wondering what the best engine oil is to use when servicing the car?
Offline OllieVRS
Re: Engine oil.
« Reply #1 on: July 03, 2023, 10:41:48 am »
If your GTI is very low mileage, I'd recommend 5W-30.
Otherwise stick to 0W-40 or 5W-40. This should reduce oil consumption in higher mileage engines and protect your engine components better.
More important than brand of oil is oil change intervals, ideally should be kept at 5k miles or under. 3k miles if you can afford to do so. Longlife servicing is what kills a lot of these engines.
But if you want recommendations for brand, I personally like Mobil 1 0W-40 and Castrol Edge 5W-40. Shell Helix 5W-40 is also good, but burns easier than the other two. Some folks in the UK go for Quantum 5W-40 from TPS, but I know nothing about it as it isn't available in Ireland.
All these meet VW 502.00/505.00 specification.
Miller's CFS NT+ 5W-40 is recommend by some track enthusiasts, but it's not certified by VW nor do Miller's say it's legal for road use. It's designed for track use and for very short service intervals. So I'd stay away from that.
'06 Skoda Octavia vRS TFSI
  • Newbie
Re: Engine oil.
« Reply #2 on: July 03, 2023, 02:14:01 pm »
Thanks very much for such a good reply!
  • -Receive: 690
Re: Engine oil.
« Reply #3 on: July 03, 2023, 03:32:26 pm »
I believe this is what the old Platinum Plus 5W40 has been upgraded to - https://shop.lrt-lubricants.co.uk/products/fuchs-titan-gt1-flex-3-5w-40-xtl-engine-oil-20-litres-lube-cube
I used it in my ED30, 2009 MK6 TDI and 330d.  Works out pretty cheap buying it in 20L cubes.  That price is plus VAT but it's still cheap.
It's VW 511.0 standard for DPF/GPFs but it'll work in older VWs as well.  DPF approval means it has to burn off/evaporate less than a non-DPF/GPF rated oil, which can only help TFSIs  :grin:
