Author Topic: Some Help Broke Down :(  (Read 12913 times)
Offline Octoparrot
  • -Receive: 103
Re: Some Help Broke Down :(
« Reply #60 on: September 22, 2023, 09:32:28 am »
Valves are out what should I be looking for here?
Those my friend are pistons.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #61 on: September 22, 2023, 09:42:31 pm »
I'm so tired  :indifferent:
05 | Tornado Red | DSG
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #62 on: September 22, 2023, 09:56:07 pm »
Do the rings spin freely by hand? If no they could have been squashed when the valve/piston contact occured.
Yes they all spin easily by hand.
Any damage to the ring lands (the gaps and part of the piston around the rings)
Not that i can see but going to clean them up tomorrow.
Now is the time to fit new rings and hone the cylinders.Especially if had high oil consumption.
Regardind the honeing is there a resonably priced tool i can buy to diy this?
This has the highest reviews of what amazon has to offer
https://www.amazon.co.uk/BGS-1265-Honing-Tool-flexible/dp/B07XZS9Y1D/ref=sr_1_8?crid=6PB0G9DVIE7L&keywords=honing%2Btool&qid=1695419927&s=diy&sprefix=honing%2Btool%2Cdiy%2C93&sr=1-8&th=1
« Last Edit: September 22, 2023, 11:01:48 pm by dazza »
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #63 on: September 22, 2023, 10:03:21 pm »
I managed to do this same thing with mine - after swapping my intercooler I managed to nick the edge of my drive belt on the AC union and the belt thread unravelled itself and posted itself into the timing belt.
Despite the financial impact, it was possibly the best thing I have done to my Mk5 - head rebuild & injector clean seemed to restore power. new valve guides & stem seal + DIY Turbo rebuild also helped - now my engine barely uses oil.
As its off, get a vacuum pump rebuild kit from ebay.
If I had to do this again, the only thing I would change is to remove the misery with both timing belt and chain - I managed to get both a tooth out in opposite directions - correctly installed, my BWA belt seems to always be 2/3 of a tooth out comparing cam & crank timing marks.
Thanks for the encouragement.
Regarding the valve guides these are easy to remove/replace.
« Last Edit: September 22, 2023, 10:48:11 pm by dazza »
Offline GVK
  • -Receive: 69
    • GVKmotorsport
« Reply #64 on: September 22, 2023, 11:31:23 pm »
I've never used that type myself, the garage ones I've used are the 3 x stone type. Can get them for under £20 off eBay I've seen.
Both types will do the job.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #65 on: September 22, 2023, 11:40:05 pm »
Thanks!
To do the honing do i need to take the crankshaft out? There are also the oil feed at the bottom of the cylinders
Offline GVK
  • -Receive: 69
    • GVKmotorsport
« Reply #66 on: September 22, 2023, 11:46:43 pm »
Just got to be careful at the bottom of the stroke not to hit the crank and oil squirters. The squirters can be removed , see Ollievrs thread about his oil pump woes.
Offline LC5F
  • -Receive: 80
« Reply #67 on: September 23, 2023, 11:46:21 pm »
I just sent my head to an engine shop for rebuild - £225 for full rebuild, including new guides.
One other tip - when reinstalling the Turbo - bolt on all the pipework that connects to the core before you mount the turbo - it will save a lot of swearing
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #68 on: September 24, 2023, 08:55:38 pm »
Cleaned the pistons up today.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #69 on: September 24, 2023, 08:57:51 pm »
Where is the best place to get the bolts? Are vag bolts on eBay well priced?
https://www.ebay.co.uk/str/vagbolts
Offline OllieVRS
  • -Given: 17
« Reply #70 on: September 25, 2023, 11:06:32 am »
For faster delivery and original quality I'd go straight to your local dealership's parts department, usually there similarly priced to eBay but you're guaranteed quality. In Ireland parts collection usually takes 2 working days (parts are shipped from the UK), so I'd expect it's next day or same day collection in the UK.
You can also go to Skoda dealerships, they sometimes sell the parts cheaper (or so I hear).
Best to call the parts departments of each just to get quote for prices, double check with them that they are quoting with VAT included, ask for estimated collection time, and then compare with eBay.
'06 Skoda Octavia vRS TFSI
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #71 on: September 25, 2023, 05:27:10 pm »
As always thanks for all your help guys.
While I wait for parts to arrive I've been trying to clean up the mating surfaces.
I've seen some videos where people use 3m disks on the block. Any tips would be appreciated?
Offline Octoparrot
  • -Receive: 103
« Reply #72 on: September 25, 2023, 06:45:26 pm »
I'd avoid at all costs anything like abrasives that will throw gritty stuff everywhere, you'll never be able to get it clean down all the passages. Use a plastic or metal scraper.
Online terrier
  • My Ride: GTI now gone
« Reply #73 on: September 25, 2023, 07:03:42 pm »
Look at 0000 grade wire wool or 3M non woven pads The white ones are the finest  I think :thinking:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #74 on: September 25, 2023, 07:10:03 pm »
I've ordered a carbide scraper. I think I have some fine wire wool. Will give it a go.
