Author Topic: Buying two tyres - pick the same, or ok to mix?  (Read 792 times)
Offline jacksosi
« on: September 11, 2023, 02:21:22 pm »
I need a couple of new tyres on the rear, as they got an advisory on the MOT.
On the front I have recent Goodyear Eagle F1 Asymmetric 5 XLs
For a pair of those locally the price is £208 fitted
The same place has the newer Asy 6 XLs for £198 fitted
So, should I keep them all the same, or go for the newer model on the rears?
Seems odd to pay (slightly) more for a previous model
« Last Edit: September 11, 2023, 02:24:42 pm by jacksosi »
Black MkV Gti (Nov 2008), no modifications
Offline terrier
  • My Ride: GTI now gone
Re: Buying two tyres - pick the same, or ok to mix?
« Reply #1 on: September 11, 2023, 03:15:42 pm »
save those pennies I would :happy2:
« Reply #2 on: September 12, 2023, 07:40:05 am »
You will be fine putting the newer version on the back as wont make a difference and come the time to replace the fronts do the same because you will be in the same situation if you put the asymmetric 5 on
Offline jacksosi
« Reply #3 on: September 12, 2023, 02:38:29 pm »
Cheers, got similar feedback from the TT forum (as the Q is car agnostic, and I have a TTS).
Surprisingly, Halfords mobile is coming to my house and fitting the 6's for £194.
I wouldn't use their branches, but their mobile fitting gets good reviews (and includes the balance and valve).
Offline jacksosi
« Reply #4 on: September 15, 2023, 07:00:29 pm »
So Halfords mobile went fine, 2x new rears loaded.
The Asy 6 tread depth seems quite shallow however, and a quick google shows it's 6.4mm, which sounds low?
We do minimal mileage so not a big issue, but it might be for someone who racks up the miles.
Offline terrier
« Reply #5 on: September 15, 2023, 07:04:22 pm »
That 6.4 will last much much longer than the 8mm i get on uniroyal rainsports :grin: :grin:
