Author Topic: Should I replace my turbo? *Attached picture*  (Read 5412 times)
Offline Reeceyy
« on: May 09, 2024, 07:38:07 pm »
Should I replace my turbo?? Looks to have a crack in it although the car is still boosting well. I do have a p0299 code popping up too with an oil leak that I'm not sure that could be related to this.
Let me know :)
Offline ZoliWorks
  • -Receive: 31
Re: Should I replace my turbo? *Attached picture*
« Reply #1 on: May 09, 2024, 10:31:19 pm »
p0299 can be a cracked turbo, fissured pcv or diverter valve. In my case, my turbo had the exact same crack as yours and was underboosting a solid 0.4bar throughout the powerband. I've replaced it with a K04 now but the turbo housing was cracked around the wastegate and the CHRA failed. The hot side blades are all scratched up and the propeller has play in every direction. Plus there was a lot of oil in the intake. I'll attach some pictures tomorrow.
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend Clutch Kit | Ta-Technix Air Intake | Ta-Technix Cat-less Downpipe | Ta-Technix Sandwich Intercooler | OEM S3 Injectors | Vis Motorsport 175 bar HPFP | 319hp 491nm
Offline Octoparrot
  • -Receive: 104
« Reply #2 on: May 10, 2024, 11:48:10 am »
I'd replace it ASAP before it lets go and causes even more problems or damage.
  • -Receive: 691
« Reply #3 on: May 10, 2024, 05:15:23 pm »
Looks like that has seen a lot of heat. EGTs got out of control.  Definitely replace it.
Offline ZoliWorks
  • -Receive: 31
« Reply #4 on: May 11, 2024, 10:12:04 pm »
Here are the pictures I promised.
