Author Topic: black vw badge ????  (Read 2317 times)
Offline Joff Gas
  • -Given: 55
black vw badge ????
« on: April 07, 2010, 12:50:47 pm »
good day....
where can i buy a matt black vw badge for the front grill? and how easy is it to fit??
cheers
Stage2plusd ed30 dsg
Offline WhiteGTI
  • F-A-S-T
Re: black vw badge ????
« Reply #1 on: April 07, 2010, 12:54:46 pm »
I think there are a few eBay sellers that do this.
Very easy to fit. Just turn the badge anti-clockwise whilst pulling slightly upwards and it will turn and release. Re-fitting is easy again, just turn clockwise and it should just click into place.
2006 E46 BMW M3 - 343hp
Offline andrewparker
  • -Given: 32
  • -Receive: 78
« Reply #2 on: April 07, 2010, 01:03:33 pm »
Got mine from Dubstop - http://www.dubstopimports.com/
Offline FamilyDub
  • ...who needs a diesel?
« Reply #3 on: April 07, 2010, 02:14:47 pm »
Do it yourself, I did my front 'VW' emblem and I've got the 'GTI' for the rear to go on in black too - it's very satisfying and not all that hard.
If you already have some stuff in the garage/cupboard like paint and lacquer it'll only cost a couple of quid to do...
If you don't have some of the materials, buy it already done. :happy2:
MKV GTI | Reflex Silver | 5-dr, Family-Spec | 17" w/anthracite Finish | Manual | Highline | Cruise | Revision 'D' DV | Dirty Pipes |
Offline Joff Gas
  • -Given: 55
« Reply #4 on: April 07, 2010, 02:38:02 pm »
cheers , do u need to prime then spray with matt black spray???? :stupid:
Offline FamilyDub
« Reply #5 on: April 07, 2010, 03:13:20 pm »
Sand using, er...  sandpaper, then prime and spray!  :happy2:
Halfrauds sell a project pack of various grades of wet & dry sandpaper for about £2.50, IIRC.
If you end up having to buy paint (£6), primer (£6) and lacquer (£?) then it's cheaper to buy it. I had all the necessary materials apart from the wet & dry, so I thought I'd give it a go.
« Last Edit: April 07, 2010, 03:15:25 pm by FamilyDub »
  • -Given: 32
  • -Receive: 78
« Reply #6 on: April 07, 2010, 03:23:35 pm »
You should also consider that if you think it ends up looking sh*t it will be pretty impossible to get it silver again!
Offline FamilyDub
« Reply #7 on: April 07, 2010, 03:51:19 pm »
Just don't do it sh*t, then.   :signLOL:
Preparation is the hardest work. Maybe a quick rub-down between coats of paint helps too.
« Reply #8 on: April 07, 2010, 04:12:58 pm »
After seeing several VW's with painted front badges, I'd never even consider it. They are nearly all pock marked with chips and look pretty awful. Either wrap it or buy a black one.  :happy2:
  • -Given: 32
  • -Receive: 78
« Reply #9 on: April 07, 2010, 04:33:01 pm »
Nah, I just meant looking sh*t in terms of the colour change, not the finish.
Offline Boothy
  • All donations accepted, thanks.
« Reply #10 on: April 07, 2010, 04:53:57 pm »
Sprayed mine and it just chipped time after time so I got bored and wrapped it in CF which is easy enough. Looks better too IMO.
« Reply #11 on: April 07, 2010, 07:18:35 pm »
I bought mine from dubstopimports too. Was maybe £16? Was quick despite being an import?
Offline joesgti
  • Eat my sick, Eat my sick.
« Reply #12 on: April 07, 2010, 07:26:02 pm »
i do mine every month, my car seems to be prone to stone chips  :sad1:
only takes 5 mins though.  :smiley:
