Author Topic: N75 replacement due to age and miles?  (Read 3295 times)
Online mjmallia
  • -Receive: 57
« on: September 16, 2024, 09:34:28 am »
Well the old girl will be turning 20 next year and making a small refresh list of things I have left  to do, as done a lot over the years to it  :confused:
Is it worth getting a fresh N75 due to the age of the car and over 100K miles, as that valve is continuously working away!
Everything appears to be working fine at the moment......call it preventative maintenance which is what I have been doing a lot of recently on it.
« Last Edit: September 16, 2024, 03:10:02 pm by mjmallia »
Mike
South Coast
Offline ZoliWorks
  • -Receive: 20
Re: N75 replacement due to age and miles?
« Reply #1 on: September 16, 2024, 09:48:24 pm »
At least for the K04, the actuator is what gives out sooner. Honestly you should be fine, but at the same time, if you wanna be safe, I'd replace both the valve and actuator.
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend Clutch Kit | Ta-Technix Air Intake | Ta-Technix Cat-less Downpipe | Ta-Technix Sandwich Intercooler | OEM S3 Injectors | Vis Motorsport 175 bar HPFP | 350hp 480nm
Online mjmallia
  • -Receive: 57
« Reply #2 on: September 17, 2024, 09:33:35 am »
I did a K04 DV relocation on my K03 quite a while ago now, so that is all fresh already.
Not sure about the actuator, so will need to read up on that one.
Mike
South Coast
Offline ZoliWorks
  • -Receive: 20
« Reply #3 on: September 17, 2024, 09:55:18 am »
One of the tuners I spoke to who also does turbo rebuilds said that the actuator should be replaced every 100k km because the membrane can develop cracks or the whole mechanism can start sticking and not moving as it should, which changes the cracking pressure of the wastegate and overall impacts the boost control. But, my K04 has well over 260k km on it and I can't say I notice any of the above.
Online mjmallia
  • -Receive: 57
« Reply #4 on: September 17, 2024, 10:05:32 am »
Mike
South Coast
  • -Receive: 690
« Reply #5 on: September 27, 2024, 02:20:56 pm »
There was an update to the N75, maybe twice, over the years, so yeah definitely stick a new one on. A bit fiddly due to the location but worthwhile.
Online mjmallia
  • -Receive: 57
« Reply #6 on: September 27, 2024, 02:23:25 pm »
Yes.....Replaced the N75 last week, as all valves start to wear.  It was quite an awkward position to get to.
Not sure if it is me, but after a quick drive the car pulls harder and feels more positive now......hard to explain, but appears to be a worthwhile task.
Original was a 2005 version D and now on a 2023 version F.
Mike
South Coast
