Author Topic: Quick question about smoke testing  (Read 545 times)
Offline MKVASMR
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php/topic,134365.msg1165175.html#msg1165175
« on: October 12, 2024, 04:20:58 pm »
Hi guys. I wanted to ask you if it’s normal when performing a smoke test with the machine connected to the intake to have smoke buildup under the valve cover? I did it yesterday and there was a lot of smoke when I opened the oil fill cap.
Offline GVK
  • -Receive: 68
    • GVKmotorsport
Re: Quick question about smoke testing
« Reply #1 on: October 12, 2024, 04:43:48 pm »
It will go through the pcv i expect  into the head.
Offline MKVASMR
« Reply #2 on: October 12, 2024, 04:47:31 pm »
So I’m guessing that’s normal. Next question. Where to hook up the smoker to test the vacuum lines. My brakes feel quite stiff although the car brakes ok.
Offline GVK
  • -Receive: 68
    • GVKmotorsport
« Reply #3 on: October 12, 2024, 04:56:15 pm »
Never used a smoke tester myself but I would check you vac booster pipe that goes from vac pump on the end of the head to the servo, they're plastic and can snap.
