Author Topic: Misfires and rough idle.  (Read 1063 times)
Offline Skapligt
« on: October 14, 2024, 01:36:53 pm »
Hello!
I thought I should try this forum since nothing else helps and Im out of ideas.
Sorry for questionable english but Im from Sweden.
SOOOO
I bought a Golf GTI 2 weeks ago, knowing it ran very bad.
Started cleaning plugs which helped but still lots of misfires.
Changed plugs, no improvement
Changed 2 injectors which were bad. The other 2 works fine
Changed coils, no improvement
Changed PCV, no improvement
Cleaned valves from carbon, no improvement
Some things I have noticed.
If I take out oil stick with engine idle it goes rough and when I put it back in it runs good for a while. Then rough again. Same with oil cap for filling.
Pretty much water/oil? in exhaust. Puddle behind car after some idleing.
I have VCDS and have checked alot with it. But not really sure what is good and what is problematic.
Compression test was good.
What is the next step for me?
I have searched alot of forums and tried it all but nothing seems to help.
Thanks in advance.
Offline PorkPieBandit
Re: Misfires and rough idle.
« Reply #1 on: October 15, 2024, 12:55:47 pm »
Have you tried unplugging the MAF and seeing how it runs? If it runs better unplugged could be that needs replacing.
Offline mjmallia
  • -Receive: 57
« Reply #2 on: October 15, 2024, 01:58:01 pm »
When was the cam belt done? timing chain done? Cam adjuster oil pressure rings checked?
Mike
South Coast
Offline Skapligt
« Reply #3 on: October 15, 2024, 06:58:26 pm »
Yeah tried that also. No difference :(
I will check the rings. But would that just affect idle? It only misfires on idle now. And now most on cylinder 4. A couple of days ago it was cylinder 3 that was worst.
Offline mjmallia
  • -Receive: 57
« Reply #4 on: October 16, 2024, 08:52:38 am »
Yes, it would make it sound lumpy and the chain would most prob rattle
Mike
South Coast
Offline mjmallia
  • -Receive: 57
« Reply #5 on: October 16, 2024, 08:53:45 am »
Have you carbon cleaned the intake valves....they clog up and create misfires like I had once......lots of info on that one.
Mike
South Coast
Offline Skapligt
« Reply #6 on: October 16, 2024, 07:01:35 pm »
No rattle at all. No problems driving. Just problems at idle.
Yes I have cleaned it. It was not too bad with carbon.
Im out of ideas soon :(
Offline mjmallia
  • -Receive: 57
« Reply #7 on: October 16, 2024, 09:26:42 pm »
A boost leak will also give a very lumpy idle.
Smoke test it and check the hoses. I had a leak from the oil filler neck extension that gave me a lumpy idle.
 The bond had gone so had to remove it and mount the oil cap direct to the cam cover.......an easy check
Also the hoses off the PCV become very brittle and crack.....those were leaking for me also, soon after a carbon clean due to their removal.
Mike
South Coast
Offline Skapligt
« Reply #8 on: October 16, 2024, 11:33:28 pm »
I´ll have to do a smoke test. Any tips for that. How to do it properly?
I´ve sprayed all over the engine to look for leaks but nothing.
Did this give you misfires or just a rough idle?
PCV hoses are new.
Offline mjmallia
  • -Receive: 57
« Reply #9 on: October 17, 2024, 05:50:16 am »
A very lumpy idle.
Are you sure they are misfires, as in you are counting them on VCDS
Mike
South Coast
Offline Skapligt
« Reply #10 on: October 17, 2024, 10:03:35 am »
A very lumpy idle.
Yepp I see them in VCDS.
