Author Topic: Forged con rods with stock pistons?  (Read 3610 times)
Offline ZoliWorks
  • -Receive: 31
« on: October 17, 2024, 09:58:58 pm »
2006 2.0TFSI BWA
Looking to fit forged connecting rods to my stock pistons, found some IE rods but they are saying they are for tapered wrist pins only. Bar-Tek on one of their blog posts say that EA113 stock pistons need trapezoid wrist pin rods. Besides IE and FCP Engineering, I haven't seen anyone else sell "drop-in" rods.
https://performancebyie.com/products/ie-rods-drop-in-144x20-vw-audi-20t-fsi?variant=39471671148683
https://fcp-engineering.com/en/audi-vw-20-25-tfsi-fsi-tsi/655-audi-18-20-16v-20v-144mm-s3-tt-.html
Would these rods fit my engine or do I need to replace both pistons and rods with aftermarket ones? Just doing rods would cost 30% of doing pistons and rods so that's why I'm more inclined towards them.
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend Clutch Kit | Ta-Technix Air Intake | Ta-Technix Cat-less Downpipe | Ta-Technix Sandwich Intercooler | OEM S3 Injectors | Vis Motorsport 175 bar HPFP | 319hp 491nm
  • -Receive: 691
Re: Forged con rods with stock pistons?
« Reply #1 on: October 18, 2024, 08:56:32 pm »
You'd be better off doing rods and pistons. The piston would then be the next weak link in the chain otherwise.  The factory hypereutectic pistons aren't the strongest. They like to crack the ring lands once you start upping the boost. I would get S3/6R spec ones as they have bigger wrist pins than GTI for even more strength.
Offline ZoliWorks
  • -Receive: 31
« Reply #2 on: October 19, 2024, 09:34:31 pm »
I figured doing just rods and replacing the piston rings is enough since I dont want to big turbo or go above 400hp. Just wanna max out that K04.
We'll see tho, I've put everything on hold till late spring, when it gets hot enough to work on the car again since no heated garage. I prolly wont do pistons and rods unless I get a hybrid K04 since with a stock one it's not worth it to put 1.5k into a car and gain 40nm of torque and 30hp
