Author Topic: Cam Adjuster data in VCDS help  (Read 2488 times)
Offline mjmallia
  • -Receive: 59
« on: October 26, 2024, 09:24:27 am »
I did my chain, tensioner and adjuster yesterday mainly due to a worn adjuster which was grooved out by the rings. I took before and after screenshot of groups 91 and 93
Before
After
But noticed that my duty cycle of the N205 solinoid block 2 of group 91 never settles in the low figures like i have seen on later TFSI's (mine is an early AXX) at hot idle testing before or after they are about the same...fluctuated upto mid 50's before the chain was done.
I have no error codes and it drives fine.
I have unplugged the cam adjuster solinoid during this testing and block 4 of group 91 goes up to 27.5KW/28KW and block 3 of group 93 for phase position remains a zero.
Am I a tooth out on the belt or something.....or worrying about nothing.
« Last Edit: October 26, 2024, 10:22:17 am by mjmallia »
Mike
South Coast
Offline mjmallia
  • -Receive: 59
Re: Cam Adjuster data in VCDS help
« Reply #1 on: October 26, 2024, 09:45:24 am »
I have cleaned the solenoid inside and out using a 9v battery to activate it, but it was very clean and about 6 years old.
Also took out the cam sensor, and that was clean too.
I have read that the duty cycle of a cam adjuster solenoid between 45 and 70 is a middle/off stage....so maybe everything is good and it does not need to adjust anything. I dont know LOL
« Last Edit: October 26, 2024, 10:24:28 am by mjmallia »
Mike
South Coast
Offline mjmallia
  • -Receive: 59
« Reply #2 on: October 26, 2024, 10:32:04 am »
Researching the hell out of this LOL
It seems that the duty cycles control the oil flow in the solenoid.
less than 50% retards timing
more than 50% advances
50% locks the timing without adjustment
I believe I am all good then, unless someone corrects me  :happy2:
Mike
South Coast
  • -Receive: 691
« Reply #3 on: October 26, 2024, 10:48:43 am »
Seems like a good result there  :happy2:
I wouldn't worry about the solenoid duty cycles. So long as the target angles are met, all is good in the world  :drinking:
Offline mjmallia
  • -Receive: 59
« Reply #4 on: October 26, 2024, 01:27:02 pm »
Thanks mate. Just wanted that confirmation  :happy2:
Mike
South Coast
Offline ZoliWorks
  • -Receive: 31
« Reply #5 on: October 26, 2024, 08:34:22 pm »
Yeah, if something was off, you'd probably notice or get errors.
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend Clutch Kit | Ta-Technix Air Intake | Ta-Technix Cat-less Downpipe | Ta-Technix Sandwich Intercooler | OEM S3 Injectors | Vis Motorsport 175 bar HPFP | 319hp 491nm
Offline ZoliWorks
  • -Receive: 31
« Reply #6 on: October 29, 2024, 08:04:41 am »
Been meaning to post these. Took the pics after a casual drive yesterday and the day before.
