All Things Mk5 > How to Guides / Troubleshooting
Engine Cover centre panel
<< < (2/2)
stealthwolf:
I thought those marshmallows tasted funny!!!
RedRobin:
On my 06-build, 05-plate GTI the clips aren't welded but have a ridged end and just pop in and out.
Chris:
mines a 55 plate 06 build so possibly the same ?
94Luke:
On our 06 Passat the middle clips were glued and the others weren't. You'll just have to see I guess.  :wink:
Ottis:
--- Quote from: Greenouse on April 07, 2010, 11:21:35 pm ---The 'clips' are heat welded onto the main cover so will need to be broken to be removed I'm afraid. When done just glue the centre strip back on.  :happy2:
--- End quote ---
I removed centre panel of my engine cover by first removing the some of the plastic weld at each attached point beneath cover,to show four slots where the silver plastic meets black cover,using a sharp blade cut each slot as deep as you can ,slowly remove centre panel ,checking each slot has been cut free,our you will break cover ,hope this helps:drinking:
Navigation
[0] Message Index
[*] Previous page
Go to full version
