Author Topic: Temp gauge dropping when heaters on  (Read 17077 times)
Offline R88TTD
  • Newbie
« on: November 29, 2024, 12:29:34 pm »
Hi guys
I started experiencing new problems with MK5 gti
The temperature gauge drops from 90 to 75 then 50 gradually as soon as I turn my heaters on
Now the heaters are blowing hot air as normal
I asked about and some tell me the battery , some tell me the temp sensor and some are telling me the thermostat, water pump was changed about 15k miles ago so that ruled out
No head gasket issues , no over heating
Just wondering if anyone had this issue before Thanks
Offline ZoliWorks
  • -Receive: 31
Re: Temp gauge dropping when heaters on
« Reply #1 on: November 29, 2024, 03:55:04 pm »
If you want to find out if it's the thermostat or not, go on the highway, drive at a constant 130-140kph without the heater and see if the temp drops. If it does, it's the thermostat.
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend Clutch Kit | Ta-Technix Air Intake | Ta-Technix Cat-less Downpipe | Ta-Technix Sandwich Intercooler | OEM S3 Injectors | Vis Motorsport 175 bar HPFP | 319hp 491nm
Offline Octoparrot
  • -Receive: 104
« Reply #2 on: November 29, 2024, 04:39:27 pm »
I'd put my money on the thermostat.
Offline mjmallia
  • -Receive: 59
« Reply #3 on: November 29, 2024, 06:18:03 pm »
Thermostat for sure
Mike
South Coast
Offline Mk5gti
« Reply #4 on: August 28, 2025, 01:59:32 am »
Hi, did you ever resolve this issue and what was it?
Offline crookedd
« Reply #5 on: August 28, 2025, 08:08:09 am »
I had the same issue years ago. Also car never reaching 90 degrees fully in winter or dropping from 90 when constant highway speeds. Issue was thermostat.
Offline Mk5gti
« Reply #6 on: August 28, 2025, 08:12:16 am »
So my issue is the needle drops when I turn heaters on
Both thermostats have been done and temp sensors using genuine parts, while driving the needle doesn’t drop, the needle will only drop at idle with heaters on
Offline matius344
« Reply #7 on: December 03, 2025, 11:54:36 am »
I got the same issue.
Anyone ? Oher ideas than Thermostat or temp sensor ?
Offline rxpx69
« Reply #8 on: December 08, 2025, 01:41:38 am »
Penguin farts
