Author Topic: MK5 GTI - Intercooler Hoses leaking again. Replacement suggestions please.  (Read 30 times)
Offline GreigC
Today I had the car serviced and hand-break cables replaced. My mechanic said my intercooler pipes are leaking again (only the drivers side) I’ve changed all the O-Rings twice now on both cooler pipes over the last 18months. I bought all Genuine seals and replaced the correct part numbers to the correct sides as one side is bigger than the other… I want to change both intercooler pipes and keep the original OEM intercooler. If I buy genuine I believe there is a cross over in part numbers depending on year. My Car is 2009 MK5 GTI. I would also consider aftermarket if recommended.
Offline mjmallia
  • -Receive: 57
Fit the S3 / Mk6 R intercooler which is larger and does away with those leaky joints. Loads of info online and did it to mine.
Mike
South Coast
Online ZoliWorks
Yeah, straight up replace your mk5 intercooler with the next one. No matter what you do, those quick connections are going to leak regardless.
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend OEM+ Clutch Kit | Ta-Technix Air Intake | Ta-Technix 200 Cell Downpipe | Ta-Technix Intercooler | Stock Injectors | Vis Motorsport 175 bar HPFP | 300hp
