Author Topic: 2 types of starting problems  (Read 1071 times)
Offline MartinNorhave
« on: February 17, 2025, 04:01:40 pm »
I experience 2 types of starting problems.
1. Every once in a while the engine just cranks and doesn't start (sounds like no spark). If I turn the ignition off and then try again it jumps right to life. Any ideas? (It is not common but it does happen about once a month. I just want to make sure that I am not stranded somewhere in the future)
2. Also not the common. But sometimes the engine has a hard time starting. Cranking multiple times before stumbeling to life. (Also about once a month)
Most of the time it starts without any problems though
Offline MKVASMR
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php/topic,134365.msg1165175.html#msg1165175
Re: 2 types of starting problems
« Reply #1 on: February 17, 2025, 04:27:28 pm »
This is a little bit more common on BWA and AXX engines. Without any logging I can't say much. Mine was fixed after walnut blasting. But it's not the first thing to jump to.
« Reply #2 on: February 17, 2025, 06:39:04 pm »
It is an axx engine. I will try to get some logs tomorrow and do a fault code search
« Reply #3 on: February 17, 2025, 09:11:10 pm »
I'm getting faultcode
P2187:004 System too lean at idle
