Author Topic: MK5 Climatronic  (Read 874 times)
Offline Mekaniko
MK5 Climatronic
« on: February 18, 2025, 04:42:55 pm »
Hello all,
I have a question regarding the behavior on the HVAC- Climatronic on your MK5. Are you happy with it?  I have another cars, A4 B7 and Leon MK3 and I just keep the clima set at 22ºC and all year it's good. But for the golf I always need to set the temperature lower or higher to obtain a comfort temperature. I don't know if it's something on the design, last year I replaced the A/C compressor now on hot days it works better but I need to set it at 18ºC for example.
No faults after scanning, maybe a temperature sensor is not working good?
Offline ZoliWorks
  • -Receive: 20
Re: MK5 Climatronic
« Reply #1 on: February 18, 2025, 09:15:54 pm »
I have the exact same thing with mine, I think it's just the clima module.
My 2009 with the new gen clima module (the one that says AC, not ECON) I set it to 22c and it's perfect for summer. With my 2006, old gen ECON clima, I set it to 18c to get the same result..
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend Clutch Kit | Ta-Technix Air Intake | Ta-Technix Cat-less Downpipe | Ta-Technix Sandwich Intercooler | OEM S3 Injectors | Vis Motorsport 175 bar HPFP | 350hp 480nm
Offline Mekaniko
Re: MK5 Climatronic
« Reply #2 on: February 19, 2025, 09:12:55 am »
Thank you for sharing the experience. Mine is a 2006, it says AC on the climatronic menu.
I have read and hear that the MK5 GTI HVAC system was not very good designed but it can not be that bad... I have the car since 6 year aprox and always had this feeling.
