Author Topic: Intermittent DSG Whine  (Read 1403 times)
Offline lazy
« on: March 09, 2025, 11:46:04 am »
The noise sounds like a dry oil pump whine. It used only happen rarely when stuck in traffic for a while and if I put it in neutral it would go away. It's now happening more frequently and also sometimes when I'm driving. I was thinking about changing the oil pump but I'm not 100% sure it's that. I've trawled Google and can't find a definitive answer to whether the oil pump is only driven when in drive not neutral. There's no oil leak so I'm sure the oil level is right as I serviced it myself about 6 months ago. Has anyone else had anything similar to this happen to theirs.
Offline mjmallia
  • -Receive: 57
Re: Intermittent DSG Whine
« Reply #1 on: March 10, 2025, 09:00:01 am »
I assume you changed the filter at the time of the DSG service and not just the oil?
Mike
South Coast
Offline lazy
« Reply #2 on: March 11, 2025, 08:10:44 pm »
Yeah, I used genuine oil and filter.
The traffic tonight and last night was quieter and it didn't do it.
Offline lazy
« Reply #3 on: April 06, 2025, 09:16:30 pm »
I might have been barking up the wrong tree with the gearbox. The last two times it's made the noise I switched the Aircon off and it stopped, so I'm thinking it's the Aircon compressor now.
Offline mjmallia
  • -Receive: 57
« Reply #4 on: April 07, 2025, 07:49:44 am »
Set the tensioner to its locked position and check the other pulleys available.......but you appear to have possibly found it.
Mike
South Coast
Offline lazy
« Reply #5 on: April 07, 2025, 10:36:55 am »
Putting it in neutral and the noise goes away really threw me out. I was definitely thinking the worst.
Offline GreigC
« Reply #6 on: April 07, 2025, 09:55:41 pm »
Most likely the flywheel. A video would help if the mic can pick it up to confirm. Mileage?
