Author Topic: Tailgate not opening  (Read 198 times)
Offline TheBALDpuma
« on: April 01, 2025, 04:19:07 pm »
A few months ago my tailgate wouldn't open, along with no reverse, fog, rear wiper and I think high level brake light.  The earth in the loom through the hinge was broken.  I had this repaired at a garage.
A week or so ago my boot stopped opening again but that is the only symptom, everything else working. So I figured it won't be wiring. Replaced the lock catch itself. No luck.  Just finished replacing the handle/switch, still no luck.
So do we think it's the wiring? Is there anything else it can be?
Offline ZoliWorks
  • -Receive: 20
Re: Tailgate not opening
« Reply #1 on: April 01, 2025, 05:54:52 pm »
Check with vcds for errors, but it's likely the wiring that runs between the boot and the body, through that rubber hose.
Mk5 Jetta 2.0 TFSI BWA | Manual | Mk6 GTI Front | BorgWarner K04 Turbo | Sachs X-Tend OEM+ Clutch Kit | Ta-Technix Air Intake | Ta-Technix 200 Cell Downpipe | Ta-Technix Intercooler | S3 Injectors | Vis Motorsport 175 bar HPFP | 350hp 480nm
