Author Topic: Bad MAF, reading max value?  (Read 1394 times)
Offline OllieVRS
  • -Given: 17
« on: April 09, 2025, 11:05:30 am »
Had this issue for a while now, but need to get it sorted as the old VRS is going up for sale  :sad1: I'll still check in on the forum every now and then to see if anyone needs oil pressure help  :wink:
MAF value on VCDS is reading the max value, no matter it is plugged in or not. Engine is running and pulling like normal, perhaps with worse fuel economy than it should have. Engine light on obviously.
Any ideas?
'06 Skoda Octavia vRS TFSI
Offline lazy
Re: Bad MAF, reading max value?
« Reply #1 on: April 10, 2025, 09:43:41 pm »
It sounds faulty, as you'd think you'd get a different reading with it unplugged and plugged in.
Offline OllieVRS
  • -Given: 17
« Reply #2 on: April 10, 2025, 10:06:03 pm »
Faulty, but where? Still reading 5V from first pin on the plug. On a healthy car, what value does it read with the MAF unplugged? Thanks  :smiley:
Offline GVK
  • -Receive: 69
    • GVKmotorsport
« Reply #3 on: April 11, 2025, 05:51:29 pm »
Have you checked for continuity along the MAF plug?
Offline OllieVRS
  • -Given: 17
« Reply #4 on: April 12, 2025, 06:10:48 pm »
Thanks for getting back to me.
I've checked first pin, live, is always 5V, the second pin has continuity to negative battery terminal, and the third pin nothing, so I assume data?
I tried getting the ECU out to test too but the annoying b*stard refuses to come out :doh:
Offline OllieVRS
  • -Given: 17
« Reply #5 on: April 13, 2025, 04:41:28 pm »
5V - 0V -0V. It seems my 12V supply is missing, I'll investigate the wiring back to the ECU. Bit of a pain to take it out the Octavia but anyway
Offline OllieVRS
  • -Given: 17
« Reply #6 on: April 13, 2025, 09:27:18 pm »
Managed to get the ECU connector out but not remove the ECU. Anti-theft cage in the way and I don't have the right tool to remove it.
5V (pin 1 MAF connector) leads to here
Missing 12V (pin 2 MAF connector) leads here.
So no issues with the MAF wiring before the ECU. Anything else it could be?
Cheers  :smiley:
Offline lazy
« Reply #7 on: Yesterday at 10:06:11 pm »
I checked mine today in case you didn't have a reference.
Pin 1 5v, pin 2 12v earth, pin 3 12v live.
