Author Topic: clunk clunk ????????????????????  (Read 5965 times)
Offline gillm
« on: April 12, 2010, 07:57:49 pm »
hi guys having a issue when turning left at full or near full lock its a clucking sound and when i wind off the lock i get another clunk . i have put my hand on the drop link whilst the lock is being put on (by a mate) and i can feel a clunk on the drop link .
i have mangaed to tighten it up a bit but im still getting the clunk . now the question is if the drop link was lose (not massivly) for 1k miles would that kill the drop link ? i have played with the ball joint and top mont but nothing . the car has done 30k if that helps ?
need this sorted asap as i have a track day on friday
west tuned gt28 @ 340hp
Re: clunk clunk ????????????????????
« Reply #1 on: April 12, 2010, 09:40:03 pm »
Are you sure its not the steering rack.  :smiley:
Offline PDT
  • -Receive: 142
« Reply #2 on: April 12, 2010, 09:51:56 pm »
would a loose droplink cause excessive wear?
Yes, depending on how loose it was. Replace it, they are less than £15 each if you use aftermarket.
Offline chungster
« Reply #3 on: April 12, 2010, 10:27:43 pm »
noooooo tis not a good time to have problems Martin!!!!
Weather is looking good for Friday.  :smiley:
Offline gillm
« Reply #4 on: April 12, 2010, 10:34:00 pm »
i was wondering if its the rack . i have had on my 3rd :( .
i know lee bad times .
« Reply #5 on: April 12, 2010, 11:12:24 pm »
I had this a while back. I replaced the top mounts and it was fine.
Offline GTIjames
« Reply #6 on: April 13, 2010, 09:54:58 am »
drop links are these the same as end links which connect the arb?
if so check these, as I recently had a clunking noise after installing arb's and it turned out to be the ball joint on the end link which had corroded over time and was loose
I replaced them with the ksport uprated end links and no more clunking
Offline gillm
« Reply #7 on: April 13, 2010, 07:56:11 pm »
all fixed . nothing to do with drop links .
Offline GLIDN
« Reply #8 on: April 14, 2010, 11:51:57 am »
So what did it end up being>??
Offline DanGB
  • Different
« Reply #9 on: April 14, 2010, 10:08:30 pm »
sub frame bolts?
Seat Leon Mk2 TFSI sport 4WD sleeper - Breaking
Buld thread: http://www.mk5golfgti.co.uk/forum/index.php/topic,45377.0.html
Offline GLIDN
« Reply #10 on: July 01, 2010, 07:30:23 am »
perhaps lower ball joints?
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #11 on: July 01, 2010, 07:40:28 am »
Tie rod?
Sepang Blue S4 BE Avant
Offline Janner_Sy
  • -Receive: 113
« Reply #12 on: July 01, 2010, 08:17:31 am »
he clunk on mine turned out to be the lower control arm mount not being tightened enough after the walk was removed
Offline matsu
  • -Given: 78
« Reply #13 on: July 01, 2010, 09:21:23 am »
i,m interested in this thread as have a few creaky and odd clunks when i,m on full lock esp slowly turning or parking etc
 :popcornsoda:
matsu
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #14 on: July 01, 2010, 11:07:18 am »
replacement hip cement loose?
Red ED35 5dr DSG
BLOG | BUILD
